Problem with spining during programs.
My washing mashine Beko WMA 510W doesn't spin. Where is a problem.
This function working sometimes but not very often.
Regards
Bogdan horoba
Try these solutions
I've just tested the water pressure pipe - pulled it up so that it was straight and that seemed to do it.
Posted on Apr 30, 2010
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
I need a manual for a BEKO AA class 1000 RPM WMA 510W
help how do i make the machine do a quick wash
Sep 12, 2010 | Washing Machines
Beko wma 1512 s washing mashine not spinning
I've just had the same problem, replaced the brushes and the problem was still there, i then cleaned out the filter, it was really clogged up, this fixed the fault, you will also need a couple of towels to soak up the water from the filter, if the machine can't empty all the water from the filter it stays there and will not move on to the next cycle thus making you think it may be a pcb fault, please clean the filter before spending money on new brushes and/or new module or getting an engineer out to it at cost to you, please also ensure you remove the plug from the wall socket before you attempt to fix any electrical appliance,
Feb 01, 2010 | Washing Machines
Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Nov 19, 2009 | Washing Machines
Washing machine flips the fuse box switch
Either the moter is jambed or timer is broken Disconnect power tip machine up and attempt to move belt manuallr it shouls with some resistance
Oct 12, 2009 | Washing Machines
Beko wma 510w will not spin
HI,
Try These
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion........
Jul 22, 2009 | Washing Machines
I have a Beko washer WMA 1613S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number...
I have a Beko washer WMA 1510S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number settings.
Andrea
Aug 30, 2008 | Washing Machines
Beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
Jan 30, 2008 | Washing Machines
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
