Oil blockage to the chain on my pole pruner. I have cleaned everything but could the thin tube from the oil chamber be blocked and if so how can I clean it please?
SOURCE: cleaning mode not pulling cleaning fluid up into chamber for cleaning process
I have had the same problem.I sent an e-mail to Remington and they sent me a whole new unit including the shaver and accesories.Problem is the replacemant is doing the same thing again as the first unit.I got it for x-mas and am getting ready to contact remington for a 3rd unit,it is only June. What I am doing now is changing the fluid and filter and tip the unit forward to bring fluid in to the head cleaning chamber.It's half ass way to have to something,but Remington does have a problem with this and needs to recall or replace with an upgrade when available
Posted on Jun 02, 2007
SOURCE: pasload cordless finishing gun - still won't fire
barrel and fan cover 'o' rings may be leaking/ need replacing. item no 17 on the parts diagram.
Do you have a spark, you should just be able to hear the spark firing when the gun is applied to the work surface and the trigger pulled, it sounds like a click.if no spark heard it could be the switch on the fan head not working , a bad ignitor , or the spark is not sparking in the correct place, chaffed ignition wires.
is the gas you are using in date, there should be a date stamp on the gas bottle. if its out of date it can give problems.
Posted on Jul 19, 2009
  • 43 Answers
SOURCE: Oil not circulating ? 1999 Nissan Altima DOHC,
Well, from the oil pump it goes into your oil filter so the lines going from the pump into the filter could be clogged. check that and see. Also on most imports I have found that they have to be primed after the oil pump has been replaced. Buy a oil pressure gauge and hook it up. Disconnect your fuel and spark delivery and then just crank over your motor to make sure you have good pressure. It takes up to 30 seconds to build on some cars. hope that helps.
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington pole chain saw model 106890-02. Chain
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. Sorry. Lou
Posted on Mar 16, 2010
kirkx
  • 2019 Answers
SOURCE: The automatic chain oiler does not get oil to the
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Posted on Mar 12, 2011
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
The 8 angle anvil pruner sku #836-7013 has a design flaw. It is not a saw; it is not a chainsaw; it has Is there a pruner like this with a better design?
I think this is one of those cutter blade type of trimmers , I do know you have to keep blades razor sharp to cut anything with them , as they do tend to go dull easy (by design) , id go with a pole pruner chain saw if your looking to replace it , but beware as pruner chain blades and chain saws are not interchangeable due to fact that pruner's are made to cut on both sides of bar , chainsaws only cut on down stroke hence have a much more aggressive chain rake , don't put a chain for this on a pruner saw you'll be putting your self at risk of injury
Oct 08, 2015 | Garden
How to fix bar oiler
try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 29, 2015 | Echo PPT-265ES Pole Pruner
Need Parts
For the pole saw parts go to the link Pole Saw
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Berlan Astkettensaege
Gerard try running the saw and getting someone to spray some WD40 onto the chain as it spins.
Apr 16, 2014 | Garden
Instruction manual for pole pruner attachment
Do not use as a coaster.
Do not use to stabilize a wobbly table.
Your pole pruner is not edible.
Do not taunt your pole pruner.
Your pole pruner is not a parachute.
Do not feed your pole pruner after midnight.
Do not use pole pruner to commit armed robbery.
Do not name your pole pruner Carl.
Do not marry your pole pruner.
Do not turn your back on your pole pruner.
Jul 25, 2011 | Flamebrain Technologies WatchMe
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need manual for homelite ut43160. what kind of oil
Chainsaw chain oil. Never let it run low!!!
Mar 26, 2010 | Homelite Garden
 Grubhead
Grubhead
