Question about Dryers
Fisher and paykel ED55 Won't start by itself, if I give it a spin manually and quickly shut the door it works fine..
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: When I switch on my
Yes, the dryer is fixable but you will need to see if it is the control board or the motor the is causing the short. Start by checking the control board for burnt spots and the motor as well.
Posted on Jan 25, 2011
ercupa190
  • 12223 Answers
SOURCE: how to remove a door switch from a fisher and paykel ED55 dryer
see the video and use the common sense. God bless you
Posted on Sep 29, 2012
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
Oct 18, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
How to remove a door switch from a fisher and paykel ED55 dryer
Sep 28, 2012 | Fisher and Paykel Dryers
Fisher Paykel GWL 15 will not drain, nor go into spin cycle. Cannot find a service manual for this machine.
normally thats a bad door safety switch,, bypass it with a Jumper wire , if it works with the jumper, replace the switch
Jul 13, 2011 | Fisher and Paykel Kitchen Ranges
How do take my fisher and paykel AD55 clothes dryer apart to check the if the belt is loose or not, because sometimes to have to manually turn the drum in order for it to start spinning again. Heat and...
sounds like the maybe the drum roller or motor, here is a video. Hope it helps Tim:
http://www.appliancerepairlesson.com/2011/03/05/fisher-paykel-dryer-access-3/
Apr 15, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Dryers Logo
15 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
