Question about Roper RT21AKXKQ Top Freezer Refrigerator
The fan in my roper freezer is not working, would this cause the fridge to not get cold but the freezer to remain cold?
  • 111 Answers
Yes this way the fan dont push air to the fresh food compartment
Posted on Jun 18, 2009
My roper refrigerator freezer ices up and the fridge is not cold. Model RT14BKXKQ05
You have a defrost problem, could be the timer not advancing, bad thermostat for the defrost system or an open heater. All of these items will cause this issue you have. the only way to find out is to test all the items. If I have to guess, I would replace the thermostat first, but its a guess as I am unable to test them. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 31, 2016 | Roper Refrigerators
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
Top freezer is working but bottom fridge is not cold
have a look at the thermostat,,,is it cutting in and out? if its not working right it wont get cold as the compressor is not told by the thermostat to start up and cool the fridge down,,, and the thermostat is the cheepest part to start with?
Jun 05, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridge/Freezer cools intermittently
It could be the thermostat. When you catch it in a cycle where it's warming up, gently tap the dial with the handle of a screw driver. If it starts chances are it's bad. If you know electricty you can jump the two terminals on the thermostat to do this test.
Aug 25, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My freezer is frozen but my fridge isn't cold
I think there is a problem with your thermostat try replacing it.
Thanks.
Please vote....
Jul 24, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
251 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
