Question about Ryobi Cultivator
Replaced gas line and primer bulb. cleaned carb, but not sure which direction the diaphram goes in. Machine idles but spits gas from top of carb and dies when throttle is pushed. Gas line routing? Seems like bulb and return line have air in them.
  • thor1115 Jun 19, 2009
    Am working on an older Ryobi 410r with a WT340 Walbro carb.
    I'm leaning towards replacing the diaphram as it will start at idle but, unable to throttle as it will die when throttle is pushed and haven't been successful adjusting the mixture screws after turning 1 1/2 turns out. Dissasembled and cleaned the carb and the diaphram seems sloppy and worn.
  • same463 May 11, 2010
    Need to know what kind of equipment you are working on.
    Usually if there is air in the bulb and/or return line it is a sign of a hole in one or the other or both.
    But if you have already replaced the bulb and gas lines this doesn't sound like the problem.
    Scholar:
  • 81 Answers
If the engine dies when you try to speed it up chances are your muffler is the problem. Any equipment that uses a gas/oil will eventually have a stopped up muffler due to carbon buildup. This restricts the air flow and the engine won't run or open up. First take the muffler off and see if you can start and adjust the carb with it off. Turn both the air and the gas adjustment screws all the way in, then back them both out one and a quarter turns. Start from there.
Unstop the muffler by throwing it in an open fire for 10 to 15 mins or using a torch to burn the carbon out. There is a screen in the muffler that I would toss out (unless you live in California) for the only purpose it serves is catching carbon. Let the muffler cool on its own, don't cool with water or you will warp it and it won't seal right. Also while the muffler is off check the muffler port and scrape off any buildup there with a knife. Hope this helps.
Posted on Jun 19, 2009
Why does the carb not prime with fuel?
Check the primer bulb. If it has a small hole or leak it will not generate the suction with which to suck the gas in to them prime the engine. And make sure that the top of the carb with the bulb is firmly attached to the rest of carb to prevent any base leaks by the primer.
Sep 20, 2015 | Garden
Craftsman trimmer 25cc
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
Apr 21, 2014 | Craftsman Convertible 25cc. Gas Line...
I need the fuel/oil mixture for Ryobi 31cc 775r gas weedeater. Also the diaphram for the fuel line replacement.
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jan 09, 2011 | Ryobi Garden
Runs on starting fluid, not fuel. cleaned carb with carb cleaner(aerosol) ,still won't run. Primer (purge) bulb doesn't work properly. Spark plug dry, fuel lines clean. Diaphram problem or something...
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Oct 01, 2010 | Poulan Pe550 Gas Edger
No gas to carb
There should not be a vent hose--it probably goes to a port on the primer bulb. Check the fuel filter for plugging and the condition of all fuel lines (they should be original rubber, not plastic replacements). Try priming the carburetor with the bulb pump--it should pull fuel into the bulb after several pushes. If nothing, check the condition of the primer bulb--it should be soft without cracks or holes.The primer is supposed to pull fuel from the tank's fuel filter, into the carburetor top section, pass into the lower section through the metering valve which is controlled by the diaphragm, then out to the input port of the primer and out the other primer port to return fuel to the tank. Go to: http://www.drystacked.com for an excellent 12 page article on theory and troubleshooting of Walbro carburetors. Hope this helps!
May 16, 2010 | Poulan Reconditioned Chain Saw 33cc 14in...
The engine will run for about a minute, then shutdown.
If it has a sediment bulb try taking it off and cleaning the bowl and use carb and choke cleaner and spray everything down. If the bolt that holds on the sediment bowl is hollow with a little weep hole in it use fine wire to make sure it is not plugged. Carefully reassemble and try it out. (When you take off the bowl the float will drop and gas will run out. Let some out in case you have water in the tank.)
If it has a carb that is mounted on top of the gas tank with 5 or 6 screws remove the tank and carb and replace the diaphram that goes between the carb and tank. An easy way to check if the diaphram is bad is to remove the air filter and press the primer bulb. If you do not get a solid jet stream of gas after a couple of presses on the primer bulb then you have a bad diaphram. Just take your model, type and code numbers (found on the engine shroud) to your local small engine repair shop and get new parts.
Hope this helps.
roundo4
Oct 09, 2009 | Garden
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Ryobi gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Jul 05, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Cultivator Logo
705 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
