Reset konica 7035
CAN I MAKE A FILE IN PDF FORMAT FROM MY KONICA 7035??
  • ELENI LOIZIDOU
    ELENI LOIZIDOU Apr 16, 2014
    I HAVE KONICA 7035 AND I WAND TO KNOW IF I CAN MAKE A FILE TO PDF AND SAVE IT TO MY COMPUTER
  • 790 Answers
Try this link for info on your unit and OS
Posted on Apr 26, 2014
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
WHERE CAN I FIND A USAGE REPORT?
press the star button to print that info press print on that page
May 28, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
First page of PDF files is printed in 10% size - rest of document is ok
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Dec 17, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Paper jam behind first paper tray in Konica 7035 copier. how do i remove the paper tray to get at the jammed paper?
Download this manual->X88BvEGG/KONICA_7020_7022_7025_7030_703.
Go to page #105-106 Disassembly/Assembly .
You will find all the instructions you need .
note:
PDF manuals require the Adobe Acrobat Reader for viewing and printing.
http://get.adobe.com/reader/
Jul 23, 2011 | Office Equipment & Supplies
Konica coppier 7035 (F-26-1 error)
Since im from Phil. =) F-26-1 mean Developing problem. Check if theres enough developer (black powder) coz sometimes it spills if ok, Go to TECH. REP. MODE screen and press ATDC ADJ. wait for 2 mins. it automatically stop it will indicate OK. Turn Off the power and On.
Jan 17, 2010 | Konica 7075 All-In-One Laser Printer
I have a Konica 7035 that has code F-35-6 show up. We found a major paper jam, removed it after taking apart part of the copier but the code remains. Any advise? Also, where can I find a manual for this...
Hello sir; Here is the way to reset this error code; press and hold down 25 while you turn on the machine, chose 1 for software switch, use up/down key to select dipswitch 3, and bit 1, then change 1 to 0 by pressing ''off".
Jan 10, 2010 | Konica Minolta DiALTA Di200 Copier
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
Computers & Internet Logo
David Payne
David Payne
