Question about Hitachi CP-X327 Multimedia Projector
How to change filter?
I need to know how to clean the air filter
Cabin filter
      How to Change Cabin Air Filter ' DIY ' NAPA Filters
      www.napafilters.com/...filter.../what-you-need-to-know-about-changing-yo...
    Feedback
    www.napafilters.com/...filter.../what-you-need-to-know-about-changing-...
    Try watching this video on www.youtube.com, or enable JavaScript if it is disabled in your browser. Open the glove box. Remove the limiting stop arm. Release the glove box. Remove the old cabin air filter. Clean filter chamber and check seals and gaskets. Install the new cabin air filter.
    How to change the cabin air filter in your car. - YouTube
    ? 1:41
    https://www.youtube.com/watch?v=bml8dletNbk
    Oct 9, 2007 - Uploaded by 1advance
    Cabin air filters help purify the air you breath while in your car. Acabin air filter should be changed every ...
    How to Replace Cabin Air Filter In any Car ;-) - YouTube
    ? 4:49
    https://www.youtube.com/watch?v=2M1yRSS333I
    Mar 19, 2011 - Uploaded by Shrek PA
Jan 20, 2016 | Cars & Trucks
How do you clean the coils?
Good Morning Friend,
I understand you want o know how to remove the coils to clean them on your Frigidaire air conditioner, model# FAS257S2A. You will not be removing the coils. If you will please start by cleaning the filter like so:
• Tilt the panel out by grasping the panel from both sides, just below the controls and the air directional louvers, and gently pull to release. Pivot the panel on its hinge's and remove the filter.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
While you are cleaning the filter, the coils will be located behind the filter area, you can clean them with a vacuum extension. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FAS257S2A WallWindow Air...
I have a 1987 Suzuki Quadrunner 4x4 It wont start unless I blow air in the air fitter box, then it runs fine. Any one know what this could be??
Have you changed the filter recently? Maybe air flow is blocked and needs cleared or cleaned
Jun 27, 2014 | ATVs
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Fuel filter
There is no need to change it frequently. If there is a loss of engine power or if throttle cuts out then may be its the time to change fuel filter. It is recommended by peugeot to change fuel filter (but depends on fuel purity) after every 36000 miles.
You can clean it yourself
Dipp the whole filter body in carosine oil tank and leave it in there for about 20-30 minutes
Pour some petrol in filter with the help of plastic piped and apply a slight air pressure (use a piece of pipe to blow) in the reverse direction (marked with arrows) of fuel supply to clear residue and heavy oil composite that clogged in filter.
Repeating the cleaning process 2-3 times will clean the filter to reuse it without the need of a new one to buy.
Jan 06, 2010 | 2005 Peugeot 405
No restart when warm audi 100
Do you checked the petrol filter? It can be simple as that.
check the MAF, the spark plugs and cabling, air filter, petrol pump.
I had the same problem with mine (same year, same model), I cleaned all the air intake system, fuel line, and now it's perfect (even needing to change petrol filter, i didn't changed it yet). Careful cleaning the MAF, if you don't know how to do it don't do it, ask an expert near you.
If you can't solve the problem this way, search for air or fuel leaks.
I solved mine cleaning the fuel line and the air intake system.
Apr 14, 2009 | Audi 100 Cars & Trucks
Air filter -
Hi, came across your post on 10-26. U need to loosen hose clamps, remove air cleaner housing bolts, then lift out filter. Clean inside housing before putting new filter in. If u need more info let me know.
Oct 04, 2008 | 1998 Plymouth Grand Voyager
Hitachi CP-X327 Multimedia Projector Logo
27 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
