Question about Casio GzOne Commando C771 Verizon Cdma
Casio comando cant recieve mms messages
Wont recieve mms messages says check apn settings
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
Cant recieve picture messages
Make sure your APN settings match.
APN: tfdata
Port: 80
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
Mar 18, 2014 | Sharp FX Plus
I cant send or recieve pics on my I phone 4
go to your settings >>>general>>> cellular network data>>>>APN-what ever company your with... user name and password leave it blankmmsc-http://mms.msg.eng.t-mobile.com/mms/wapenc mms proxy-216.155.165.50:8080mms max message six 1048576
Nov 21, 2012 | Apple iPhone 4 Black Smartphone
I cant recieve multimedia text messages
GOT TO HAVE APN FOR MMS.APN-ACCESS POINT NAME .CONTACT UR CUSTOMER CARE HE WILL TELLU APN.
VOTE FOR ME IF PROBLEM SOLVED.
Sep 03, 2011 | Motorola Mobility RAZR V3
I have 8900 blackberry curve My problems is i can recieve picture messages but cannot send, I was able to do this before and i have contacted my service provider t-mobile who do not seem to want to...
It sounds like you have overridden the MMS settings provided by TMobile. Have they resent these settings to you? Save these as you did previously, and you should be able to carry on.
Check you have send via MMS option from a contact in your address book.
May 12, 2009 | Cell Phones
Nokia 6085 on att won't send or receive mms/multimedia messages
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: wap@cingulargprs.com
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
at&t apn settings 4Gdetails: If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
May 12, 2017 | Samsung BlackJack II Smartphone
Lg me770 shine. how do i set up to have mms
i used this for mine. it works alright for recieving and sending. but im still having trouble recieving from black berries.
go to menu
settings
connectivity
network
network profile
bearer: GPRS
APN: wap.cingular
user ID: blank
password: blank
primary server: 0. 0. 0. 0
secondary server: 0. 0. 0. 0
then press ok.
now go to menu
messaging.
message settings
multimedia message
network profile
profile name: Cingular MMS
internet mode: http
proxy ip: 066.209.011.032
proxy port: 80
connection: media net
hopefully this works for you guys.
Dec 11, 2008 | LG Shine KE970 Cellular Phone
Casio GzOne Commando C771 Verizon Cdma Logo
14 people viewed this question
Top Casio Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
