Have subwoofer sound, but no speakers - Audio Players & Recorders
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
You'll have to provide more information, such as make and model.
Posted on Aug 04, 2015
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Surround Sound Speaker
It sounds like you need to define the speakers to the PC. Find the icon that controls your Sound Card and dabble with it.
Dec 26, 2009 | Audio Players & Recorders
I am trying to hookup my AL subwoofer to my existing comp system.Inserting a wire jack into one of the comp spkrs and subwoofer shuts the sound off.?? It is a FMC0034326 Altec Lansings Subwoofer.Thanks.
You can't just do that. Your sound card needs to have a specific jack just for subwoofers. If you plug it into the speakers, the computer recognizes the subwoofer as a pair of headphones and routes all sound through it. Remember, a subwoofer is not a normal speaker. It only allows a frequency of extremely low sounds (a.k.a. BASS) and won't play anything that you would need a tweeter for.
Jun 11, 2009 | Altec Lansing Multimedia Computer Speakers
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
Subwoofer power but no sound
sony suks.is it a powered sud?if not take any battery and touch the leads on the speaker if u get a sound speaker is workig.
Dec 06, 2007 | Sony Xplode P5 Turbo Subwoofers Car...
have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
Nov 07, 2007 | Tannoy Sensys 7 Speaker
74 people viewed this question
 Grubhead
Grubhead
