Question about Hitachi 27CX01B 27" TV
Hitachi 27AX1B immediately shuts off at startup
TV shutdown while watching, and would not restart. After unplugging and replugging, it starts the startup sequence but immediately shuts back off and the only way to get it to start the startup sequence again is unplug and replug the set. Removing the back, I found the C274, split and it sparks and smokes when you attempt to start the set. On the Internet, one site states Hitachi recommended remOving this C274 completely, and in the case of one user this fixed the problem. On my set I did this and it was working perfectly for about three minutes. Now I am back to it immediately switching off after starting. Other sites talk about replacing the Q711, and I was wondering if you had some other ideas.
You are going into shut down check regulator check for bad solder connections get back to me
Posted on Nov 02, 2007
Hitachi 65f59 65 TV keeps shutting off
This set uses a number of green L.E.D.'s inside which are tied to different voltages---if you can watch them when set shuts off you are looking for one that goes out either quickly or after the others--points to area (voltage) where problem may be.
Other visual indications are screen changes red, green, blue right at shutdown and sound and brightness then both vanish=shutdown circuit being triggered to protect the set.
May 15, 2012 | Hitachi Televison & Video
Sharp 25L-S180 immediately cuts off
Set is in shutdown as there is a problem somewhere inside--either it is worth a shop looking at and or repairing or it is time for a new set.
May 13, 2012 | Sharp 25L-S180 25" TV
Due to c00002la fatal system error problem I am unable to shut down.
Shut down your PC by pressing restart button then immediately shutdown button, Next time when you start your PC, press F8 during startup before the window logo comes up, and choose "last configuration that worked". If the last known good configuration does not work you may have to reinstall the operating system. Visit this link to resolve this error.
Nov 26, 2010 | Computers & Internet
I have a Hitachi P50T501 plasma tv. The screen went blank while watching it. We have been unable to watch tv or dvds. The power light is blue.
Tries unplug,replug about 1 hour later,if doesn't work,than Ur main video backlight board it dead,must replaced.
Nov 20, 2009 | Hitachi P50T501 50 in. Plasma HDTV
Toshiba TP55G60 shuts down and red light blinks
Check the powersupply for loose solder conncetions. Especially in the protect circuit.
There is a white waffer looking IC that has been known for the pins to pop open from the
high frequency output of the power supply.
The Powersupply is on the right side and pretty easy to tell. Please use caution when
working on this set because the caps in the powersupply can hold a good charge. If you have any doubts about doing it yourself, call a professional and hopefully the pain in the pocket won't overcome the pain threshold.
Good Luck,
Jun 17, 2009 | Toshiba TP55G60 55" Rear Projection...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Mar 18, 2008 | Televison & Video
Problem while pc shutdown and startup
unplug it from the wall for 10 sec. and then plug it back in and restart.
Mar 15, 2008 | Computers & Internet
Hitachi 27ax1b volume problems
If the audio is not distorted, but low. I would suggest a coupling capacitor from the audio processor to the audio output amp ic.
Feb 24, 2008 | Televison & Video
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
Hitachi 27CX01B 27" TV Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
