Question about Kyocera Taskalfa 300ci With Feed, Print, Scan - 101k Copies
Kyocera Taskalfa 300ci druckt nicht mehr, scannt aber.
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
Joed911
  • 4338 Answers
SOURCE: Ich habe ein Problem mit
Siehe, wenn es irgendein Papier gibt, das von den Walzen gehaltt wird. Wenn doch entfernen Sie es. Reinigen Sie dann die ganzen Walzen mit einem feuchten Tuch.
Posted on Nov 18, 2010
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
SOURCE: Free service manual with code
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Posted on Aug 24, 2011
300ci will not copy 2 sided documents
from the copy screen touch the duplex button on the display and choose 2 sided > 2 sided. if it is not available in the menu the duplex unit may have failed repeatedly and shut itself down in which case you would need to go into simulation mode and perform a u906.
Sep 29, 2014 | Kyocera Taskalfa 300ci With Feed, Bank,...
Kyocera taskalfa 300ci
10871087 to enter service mode. There are 2 maint. kits for the 300ci. One for color and one for mono. If you were able to perform a maintenance then you should be well versed on which adjustments to make and which counters to reset. If not you can cause major problems so be careful.
Dec 16, 2013 | Kyocera Office Equipment & Supplies
C3300 error in kyocera taskalfa 820
I have actually discovered another cause of the C3300 error on Taskalfa machines .. Mainly the 250ci - 552ci (300ci, 400ci included) .. If you look at the mirror assembly there are 4 plastic pads that glide on the rails. I discovered 2 on the left side damaged causing the mirror assembly to sit at a slight angle .. Got these replaced and it works great!! I hope this helps!!!
Sep 11, 2012 | Kyocera Office Equipment & Supplies
Sehr geehrte Damen und Herrn, ich habe mir einiger zeit eine Che-ez 2.1 Megalpixel Camera gekauft aber ledier ist der dazu gehörige Akku **** geworden und somit nicht mehr...
Sehr geehrte Damen und ich spreche nicht Deutsch, aber Google Language Tool ?bersetzung hat mir geholfen. Die Kamera braucht eine Batterie vom Typ AAA in den meisten elektrischen Gesch?fte gefunden werden. Der Blitz braucht eine CR-2 Knopfbatterie h?ufig in Computer speichert.
Dec 16, 2010 | CHE-EZ D'zign Digital Camera
Hallo ich brauche euere hilfe seit 3 tagen komme
Das ist ein Problem mit der Facebook-Website. Der einzige Weg, es zu beheben ist, indem Sie die Support-Team und lassen Sie sie wissen, der das Problem gelöst. Wir hier bei Fixya müssen nicht die Mittel, um dieses Problem für Sie lösen. Danke.
Dec 07, 2009 | Facebook Social Network
Error 1506
1. Restore factory defaults 2. Don't fill out your account at this time 3. Activate Traffic info and subscribe to the trial. Download traffic info at least once 4. Fill in you account in the Plus-services. 5. Enjoy!
Oplossing voor verkeersinformatie: "Er is een fout opgetreden - probeer het opnieuw, of neem contact op met de klantenservice. Error code 1506".
Inmiddels werkt het weer! Via een Duits forum ontdekt: 1. Herstel fabrieksinstellingen 2. Vul NIET meteen je eigen account in, maar meld je aan voor de trial verkeersinformatie 3. Vernieuw de verkeersinfo. 4. Vul nu je eigen account in 5. Et voila ! Het werkt!
Naj, klappte nicht, ABER ich hatte eine neue Fehlermeldung "error code 1506". Immerhin etwas neues, also muss dies schon etwas bewirkt haben.
3. Mit ein bisschen "Schnorcheln" im Internet fand ich auch einen thread (wo weis ich nicht mehr) in dem mehrere Lösungsvorschläge zur Beseitigung dieser Fehlermeldung waren. Ein dokumentier NICHT erfolgreicher war.... Na, kommt Ihr drauf? Genau, den tomtom support zu fragen!!! Ratet mal, was die dem Kerl erzählt haben? Bingo! Geräte Inkomptibilität, wir sind nicht Schuld.....noch 'ne tote Sau (die ha'm wohl da 'nen Schlachthof in ihrem Support-Center...). Ein logischer, aber mühsam/ärgerlicher war folgender (Reihenfolge unbedingt beachten!): a) Im navigator unter "Einstellungen" den Button "Standard wiederherstellen" drücken (ja, ich weiß, alle Settings, Favoriten und persönlichen Einstellungen werden gelöscht, und die wenigsten wagen es, ABER TU' ES!!!!!). Vergiss' die Sicherkopie Deiner "mapsettings"-Datei, die macht Dich nur unglücklich, kannste, neh musste Dir sparen!!! b) Dann bloss nicht Dein tomtom plus Konto einrichten!!!!! Sondern Verkehrsinfo einschalten drücken. Du wirst gefragt, ob Du Dein Probemonatabo nehmen willst. WILLST DU! Ja drücken!!!!!!! c) Verkehrsinfo funzt wieder!!!!!!!!!!! . So jetzt darfste Dich in tomtom plus mit Deiner email-Adresse und Passwort wieder einloggen. ALLES WIEDER O.K.!!!!
Jul 07, 2008 | GPS
Kyocera Taskalfa 300ci With Feed, Print, Scan - 101k Copies Logo
24 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
