Question about ESCHMANN Little Sister Autoclave Tabletop
Error 3 Little Sister 5 Autoclave. Error 3. This message keeps coming up and I have cleared and re-sett the machine and dried the water senors as requested by the manual but keeps bleeping this message after 20 seconds of starting a programme. Any help gratefully received
    Scholar:
  • 125 Answers
If your manual states it is a water sensor problem then you are probably looking at an LS3 manual not an LS5. LS3 error 3 is "Chamber did not fill with water which is different to LS5 error 3.
Posted on Feb 23, 2015
  • TekkiDave Feb 23, 2015
    Error 3 on an LS3 is due to water sensor so are you sure you are looking at the right manual?
    Habit-Forming:
  • 55 Answers
Change the door switch...
Posted on Jan 04, 2015
  • 25 Answers
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Posted on Oct 29, 2014
My sterilizing autoclave, SES 2000 Little Sister has flashed with error ELECT on the screen, it apparently has something to do with a power cut we may of had today, but how do you fix it?
Check the fuses located on both sides of the mains connection in the back of the autoclave. One of them has blown. If both check ok, then check the connection tho the mains. You may have a faulty ground. If you are not comfortable doing this, contact Eschmann at tel:+44 (0)1903 753322
Fax: +44 (0)1903 875789
info@eschmann.co.uk
Mar 06, 2018 | Science & Laboratory
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Feb 09, 2015 | Washing Machines
At aproc 103 degrees I get ERR1. Any ideas what is wrong
Here is a link to the technical manual:
http://www.njcautoclaves.com/pdf/LS3-None-Vac-Parts-Explosion.pdf
It doesn't list an error code of 1 just 2-9 so I have no ideal.
Nov 29, 2014 | Cars & Trucks
What is the solution for error 4 appears on autoclave little sister 5
Visually check for obstructions on the door seal area. Clean gasket and its mating face. Run Cycle again.
May 25, 2014 | Science & Laboratory
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Little sister autoclave
A bit more info, In what make, model Laptop?
Apr 23, 2013 | Computers & Internet
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Three buttons keep blinking: clean, water and
Hi
First I would start off with priming the machine. Push the water button ( right button) open the steam knob and see if the light will clear? If it doesn't you have a restriction in your flow meter.
If light clears, go to the next light, which is the clean light (left button) Push and hold for 5 seconds until it starts then let it go until it clears. About 30 to 45 minutes.
Then you need to descale. If you have never done it email me.
Mar 13, 2010 | Solis Palazzo Espresso Machine
ESCHMANN Little Sister Autoclave Tabletop Logo
1,226 people viewed this question
Top ESCHMANN Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an ESCHMANN Science and Laboratory Expert? Answer questions, earn points and help others
