Question about Makita BMR100 Radio
Not working from the 18v batt - Makita BMR100 Radio
Does somebody have a schematic of the PCB inside of Dewalt 18v lithium ion battery. In particular, the P/N of the power transistor. Thank You
You'll have to contact Dewalt for that info--this is a reach---also I was unaware that there was a circuit board inside a 18V lithium ion batt---GL
Dec 20, 2016 | Dewalt Drills
18 v. ridigid cordless works tools for a feww sec. then stops batt is charged same in all tools
bad battery. cells won't hold a charge. that's what it sounds like to me. batterypackrebuilders.com for a rebuild or buy a new one from home depot.
Jun 23, 2014 | Ridgid 18v Drill R86007 Rigid
18v lith ion Battery charger 12v makita will not charge battery? why? why?
I also have the same dilemma,and of course,it occured 1MONTH after 1year warranty expired.I know my batts r still fine,as I recharge em on my foremans kit.
My charger plays a tune,then just blinks red,green....etc.Wish I had some tips to try,from an electronics brain-type person.......lol,good luck::
May 11, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
Xrp 18v dewalt drill worked fine with plenty of juice in battery and suddenly stopped working. What could be wrong with it?
if your batts are ok and the batt connection terminals look ok you may have either faulty switch burnt off wire at brushholder or reqire new brushes
Nov 10, 2009 | Dewalt DC988ka 18 - volt XRP 1/2''...
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
I HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Jun 20, 2008 | Dewalt 18 Volt Compact Drill Kit
Makita BMR100 Radio Logo
46 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
