Question about Fisher and Paykel CT560QX 23 in. Electric Cooktop
When I turn the double plate on or two plates on, a clicking sound heard and lights flash on and off, then the stove turns off.
Serial no. NAD292344
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: The double hot plate only works in the center
I note this cooktop came with a 2 year warranty.
All of the elements are controlled by item 16 of this manual:
http://spares.bigwarehouse.com.au/file.php?document_id=6100
You will have to click on your model number to see it and probably have to enlarge the view.
The part number is 532037 but crosses to 533023 on several websites and sources.
If your having to pull the wall plug to shut it off this is the most probable failure.
Expensive part but most likely what it will take to correct your problem.
Thanks for choosing FixYa.
Kelly
Posted on Sep 10, 2010
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
I have a Jennair model ccg2423 stove top.Only one burner ignites yet the clicking sounds seems heard on all 3 others
Hello, Thank You for using FixYa. I will be helping you today.All four ignitors will spark even if only one is turned on.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
We have new house and have cold air coming from Jenn-air vent. What can be done to stop this? We had a Jenn-air in our previous home and did not have this trouble
Most stove vents have a diverter plate which prevents air from coming in. When the fan is turned on, this diverter is opened by the air flow and allows the air to flow through. It sounds like this plate is either stuck or was not installed when the ventilation duct was installed.
Oct 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
Stove keeps tripping fuse
when turning on stove, the current inrush is too great for the breaker. you need to look at the data plate on stove first to see if the current (amp) usage is greater than your breaker. If not, then you may have a faulty element or control
Jul 02, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Fisher and Paykel CT560QX 23 in. Electric Cooktop Logo
69 people viewed this question
Top Fisher and Paykel Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
