Question about Miele Microwave Ovens
Remove built in oven surround
Unable to remove the surround from a built-in Miele M635EG microwave oven
MicrowaveSvc
  • 9098 Answers
SOURCE: removing microwave surround
Ahh, that's one of those British brands I can't get any information about.
If you have the installation instructions, they would tell you how to install it, and it's as simple as reversing the procedure.
BUT maybe it's not too different from US models in the sense that many of its components can be accessed without pulling it from the wall, assuming it's the over the range type.
I would first refer you here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
In most cases, you unplug the oven, then remove the vent grille across the top, then you'll see a screw holding the top of the control panel frame in place.
Once that screw is out, you probably lift up and either swing forward or twist to loosen the control panel.
You should be able to access the fuse, etc. at this point.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If it's built into a cabinet, then you would have to remove the metal frame covering the area in which the microwave rests.
Be safe.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
Posted on Mar 31, 2008
SOURCE: trying to remove built in Kenmore microwave 1994 #89755?
A family member removed it while I was away. Returned home a short time later & it was outside under the C/P. Thanks anyway.
A.J.M.
Posted on Dec 30, 2008
  • 52 Answers
SOURCE: sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Posted on Feb 23, 2009
greenspan
  • 1734 Answers
SOURCE: Schematics for Miele Microwave M637-1EC Electronics
Ask them, they can get you many Miele schematics.
Posted on Jul 14, 2009
I am unable to close the door of my Miele microwave oven model M8260. Is it possible to fix this?
I assume you mean that the door can be closed but will not stay secured shut. The only way to tell is to take the cover off and inspect the latch assembly. I have found that a small spring can break. It can usually be found at your local hardware store.
Nov 19, 2017 | Miele Microwave Ovens
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
Microwave oven H-4020 BM...... How to clean inside????? I am unable to get the stains off and inside looks terrible.
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | Miele H187MBALU Convection/Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Sparking roof of my miele M613G microwave
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
Remove built in microwave Baumatic BTM231SS 900 from cabinet
Hi Brunie1,
They are on popers so with a knife being careful not to bend either knife or surround gently prise 2 strips either side of door. this should then reveal the 4 screws
Mar 25, 2008 | Baumatic BTM231SS Microwave Oven
Removing microwave surround
Be safe.
Mar 19, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
