Question about Refrigerators
Srs615dp WHEN DUMPING ICE, THE ICE TRAY OVER-TWISTS DISLODGING THE TRAY FROM IT'S MOUNTING PIVOT POINTS. THE DRIVE CONTINUES TO OPERATE AND REVERSES BACKWARDS AS NORMAL BUT BECAUSE THE TRAY IS NOW OFF THE MOUNTING POINTS IT IS UNABLE TO RETURN TO IT'S UPRIGHT POSITION READY TO RECEIVE IT'S NEXT REFILL FROM THE FILLER TUBE INSTEAD REMAINING IN AN UPSIDE DOWN POSITION.
catriver
  • 878 Answers
SOURCE: Ice Maker not dumping
Sailor, Samsung put out a service flash on your model regarding the ice maker fill tube. What is happening is that ice is forming on both ends of the fill tube. When the ice tray twists in the harvest it is hitting on the fill tube and pulling it from it's mount. Could this be why the drive motor seems to weak. The flash number is ASC20060525001. They redesigned the fill tube, part number DA63-02928A. Just trying to help you find an answer...Catriver..post back.
Posted on Nov 15, 2006
SOURCE: Ice tray sometimes stuck when dumping off ice
I am an attorney near Philadelphia who is considering initiating a class action against LG related to the defective design of their ice maker. I have clients in different states who have had problems that LG fixed, but the problems re-occurred after the warranty expired. I've been advised by mechanics that leaks are inevitable based on the design. Apparently this is a design that LG had used years ago but had discontinued for a while because of leak problems. I'm usually on the defense side of product liability cases, but this seems to be a common defect. If you are interesed in such a suit, feel free to contact me at corrlaw@verizon.net. Law Office of John A. Corr, (610) 482-4237.
Posted on May 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Please help. I have a Samsung RS2555SL
I will assist you with your ice maker problems if you like, Thanks Sea Breeze
Posted on Nov 26, 2009
  • 91 Answers
SOURCE: lg lfc 21770 ice maker
The defrost heater on your ice tray has failed, Replace the ice tray is only solution, sensors are having trouble as well due the heater problem. Does not know where it is in the cycle, also sounds like the gear on the ice maker is shot due to build up, replacing the ice maker should sort all issues out. If you cant find one, send me a email to WGHEAVEN@Yahoo.com.au and I'll send you one. Regards Russ
Posted on Jul 03, 2012
  • 25 Answers
SOURCE: Ice Maker arm is locked in upright position, will
check ice pump.
Posted on Aug 25, 2013
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Install Plow on Sears tractor
Going with the garden tractor, I have one. The cutting deck should be removed primarily because the deck could drag on snow. Some of the pivot points for the blade go where the mow deck mounts. There can be an additional fixture to mount on the body of the tractor frame to operate the lift for the blade. There can be additional brackets to support the blade and offer a 4 point mounting system.
Dec 03, 2012 | Garden
What would cause the convertable top malfunction?
ALL CONVERTABLE TOPS HAVE SEVERAL PIVOT POINTS THAT MUST OPERATE SMOOTHLY TO RETRACT AND CONTRACT TO THE CAR! ALSO A MOTOR HAS TO OPERATE ALL THIS OPERATION! IF ANY OF THOSE PIVOT POINTS ARE BENT, RUSTED, OR NOT WORKING PROPERLY, IT WILL CAUSE A MALFUNCTION!
Feb 28, 2011 | 2008 Chrysler Sebring Convertible
Ice maker seized after dumping ice, will not return to fill position
OK, Now I see that model number is only for the UK. I did find a supply and hopeful supply warehouse Ckick Here=> Big Warehouse the location is Australia. They have parts manuals with your model numbers. Like this PDF of your model Here=> SRS615DP I would like to say I know your machine but all model numbers change in the USA I am trying to help and if you are from another county I will also give that a try, Tell me this OK or not, I would like to know because I get many questions from Australia, Thanks, Sea Breeze
Mar 17, 2010 | Samsung Refrigerators
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Nov 15, 2006 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
