Question about Emerson EWF2703 27" TV
Cant get out of service menu? no remote
I have a emerson EWF@&)# t.v. and when I turn it on the screen is all snow. there is a number 2 in each corner of the screen along with this 054-0.05 272 then a small black rectangle box right next to it.(this is across the top of screen) then in the lower left hand part of the screen has OD 643D. I am assuming it is in the service menu possibly. I don't have a remote. Is there a way to get out of whatever menu this t.v. is in in order to program a universal remote to operate this t..? this is what appears everytime it is turned on. How can I get this t.v. to a normal screen?
SOURCE: Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Posted on Feb 06, 2008
SOURCE: universal remote codes
here are some codes that might work 0456-0004-0009-0044-0135-0049 the first one might be it if you don't know how to set it here's how press setup and hold it until the light stays on then press t.v. and then the code. hope this helps
Posted on Oct 31, 2008
SOURCE: emerson tv stuck in video mode
Done - channel scan put the TV back in the correct mode
Posted on Nov 19, 2008
mie999s
  • 105 Answers
SOURCE: lost remote and cant find code for universal remote
146 or 155 try ok
Posted on Jun 07, 2009
  • 74 Answers
SOURCE: yes i have a emerson tv but have a universal tv
try these codes.0177,0087,0714,0247.1909,0486,0370,0163,0361,0178
0178,0037,0556. Hoping ones thses work if not contact remote mfs as some sets require update
Posted on Mar 04, 2010
We gave an Emerson 50 tv. The picture is too large for the screen. For instance, you can't see the score for the football game. On the remote, I adjusted with button on the remote for picture size.
Just initialize the TV. It will make it alright to factory conditions. Proceed.
1. Turn the power on.
2. Enter the service mode.
- To cancel the service mode, press [POWER]
button on the remote control unit.
3. Press [BACK] button to enter the Panel Key
Confirmation Menu.
4. Press any button on the touch sensor panel.
5. Press [INFO] button to proceed with the self check
mode.
6. Make sure to confirm the "INITIALIZED FINISH"
appears in the green screen.
7. Unplug the AC Cord and plug it back on again.
Sep 11, 2016 | Emerson Televison & Video
Rm500 codes for symphonic tv
Sharing this info for anyone who may find it of some use for other Emerson/Funai/Symphonic tv's...
I stumbled across this on a random day trying once again to figure out the service menu on my Emerson LC320EM8, by basically digging through every funai LCD service manual I could find on funai's german ftp server online. As these remotes seem fairly universal to all Emerson/Funai/Symphonic (as well as Most no names or store branded) tv's......give this a try..
There's a hidden "service" button on the remote located below and in between the locations of the CH +/- and VOL +/- buttons....you have to cut the bezel on the remote to reveal it...
How to initialize the LCD television:
2. To enter the service mode, press the service
button on the service remote control unit. (Refer to
page 5-1.)
- To cancel the service mode, Press POWER button on
3. Press INFO button on the service remote control
unit to initialize the LCD television.
4. "INITIALIZED" will appear in the upper right of the
screen. "INITIALIZED" color will change to green
from red when initializing is complete.
Hope this info is useful to someone else...
regards,
Gio.C
Apr 10, 2014 | Televison & Video
2004 EWF emerson canot get to video and lost remote
i too have an emerson television on your tv there should be a button that says input just click it to the setting you need
Feb 01, 2013 | Emerson EWF2004 20" TV
Att remote code for emerson EWF 2704
Almost impossible, Emerson uses odd codes and for that reason charges a lot for a new remote, if you can even find a new one.
Cable provider remotes have less than sixty average codes built into them so I doubt that remote will work on that emerson.
Dec 15, 2012 | Emerson EWF2704 TV
Have numbers and letters on screen and wont go away, im able to see the picture but no sound sound from tv. these are the numbers that appeared on screen 058-0.06 271 A1 (top) 0F F6FD (bottom) and the...
U have the tv original remote wright?This problems likely parts of Close Caption problems.Look for a button that said CC on the remote press it make sure all like CC1,2,3.. to off should solved this problems.Or tries go into the main tv Menu looking for Close Captioning functions turn off to all CC1...and Text1... all to off.Will fixed this problems.
Jun 07, 2011 | Emerson EWF2004 20" TV
Hi i bought a SAMSUNG DVDF1080 and it will only play PAL dvds do you have an unlock code? cant find one that works. thanks
1.- Without any disc in the tray turn on your player
2.- Wait until the sign “no disc” shows up in the left up corner of the screen
3.- Press “info” button in the remote (“no disc” should disappear from the left up corner)
4.- Press in the remote the code corresponding to your region
R1 - 29334
R2 - 38767 or 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 – 24462
5.- The number of your region should appear in the left up corner of your screen
6.- Press the button “9” in the remote
7.- Press the button “repeat” (is under the number 6) in the remote
8.- Turn off your dvd player,
Sep 20, 2008 | Televison & Video
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Aug 25, 2008 | Orion STV2763 27" TV
Emerson EF 2703 - Infrared Beam is not functioning
John,
I am having this same issue with an Emerson EWF 2702. Did you find any resolution to this. Do you know of a way to change the video input on the tv when you cant use the remote?
Thanks,
Jack
Jun 26, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson EWF2703 27" TV Logo
32 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
