Question about Avaya Computers & Internet
Voice box turn off - Avaya Computers & Internet
My tv went black no picture , I have voice but no picture what do I do?
Hello CJ, try unplugging the cable box and the TV, then plug them back in, also unpluging the cable box from the TV, then plugging it back in. Let's hope one of these fixes it.
Bill
Oct 25, 2014 | Televison & Video
Sound does not work on Garmin Street Pilot GPS
is sound enabled in the settings? I will get you instructions if you provide me with your model.
also you could try reseting the device, there is a reset hole or button. Model would help.
Thanks,
Ekse
Oct 23, 2008 | Garmin GPS
It makes a rattling sound when i turn it on
It could be the box. Boxes wear out over time and get loose. If not then its the voice coil. Theyre not blown all the way but youve done damage and burned some voice coil. I have 2 of them with bad voice coils that do that rattling. But they still hit super hard. To find out take the sub out the box and turn it up. If no noise then its the box.
Apr 24, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
How do i setup my N73 voicemail
sir the voice mail box is a network service to which you may need to subscribe .for more information ,contact your service provider .to call your voice mail box ,press and hold 1 .........to edit your voice mail box number ,select menu >messaging >voice messages >voice mail box select the following settings to setup the voice mail
Nov 23, 2010 | Nokia N73 Cellular Phone
VOICE turn by turn has quit working. How do I restore voice.
Check that the mute box is not ticked.
1. Press Tools, Settings, Language and then press Voice. Select a new voice.
2. If that doesn't solve the problem it may be that the voice file has become corrupted. Connect the satnav to your computer. Download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 When it's installed it will look for updates to your satnav software. After this it will give you the option to download voices. Select the ones you want and click next. The voice files will be downloaded to your satnav.
When you've disconnected the satnav from your computer select the voice you want as described in paragraph 1 above.
Aug 13, 2010 | Garmin nuvi 750 GPS Receiver
Deleted main voice mail
you will need to have the admin program and a cable to connect to the system to re-make the mail box 990 or call a forwarded phone and get their voicemail box and press star and log into mail box 999 and create the user 990. If its older and you have a keyboard and monitor simply make mail box 990 and turn on DND.
Jan 22, 2010 | Toshiba DKT2020SD Phone
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
Voice mail message icon won't go away
first inactive ur voice mail service. then check outbox if any outgoing sms or voice mail r there then delete it.
Jul 30, 2009 | Nokia 6085 Cellular Phone
MY TOMTOM ONE DOES NOT GIVE ME SPOKEN STREET NAMES AS THIS MODEL SHOULD,CAN U GUIDE ME THE SETTINGS
These steps are for my TomTom One (2008) model.
1. Once you have turned on your TomTom tap the screen.
2. Tap 'Change preferences'
3. Tap the arrow to get to page 2 of Preferences
4. Tap 'Change voice'
5. Tap arrows until you get a computer voice - I chose Samantha.
6. Tap the 'Select' button to the right of the voice picture.
7. This screen is labelled 'Speech preferences' and the first one is 'Read aloud street names'
8. Tap the box to the right to select this preference.
Good luck.
Sep 12, 2008 | Tomtom GPS
Computers & Internet Logo
82 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
