Question about Sony Cfd-s33 Cd Cassette Recorder Am Fm Radio Boombox, Working
Sony cfd s33 cd player doesn't recognize read cds in boom box
Sony cfd cd player always says 'no disc' when we put a cd in while in cd mode
5 Suggested Answers
  • 49 Answers
SOURCE: My sony CFD-E100 won't recognize CDs
use a cotton swab to clean the optical lens-which is seen by opening the CD cover. if after cleaning the lens it still doesnt play a cd - exercise all manual switches(could be a dirty cd/radio switch), several times. after these steps, and the cd still refuses to spin...its hopless. the optic is bad.and not economical to repair. bet the cotton swab does the trick.
Posted on Mar 04, 2010
SOURCE: my sony cfd zw155 will not play cd's they start to
The internal laser lens might need cleaning due to dust build up with a CD Cleaner or the Lens has Become faulty but most of the time it will be a dirty lens
Posted on Apr 09, 2010
  • 5370 Answers
SOURCE: Sony boom box model# CFD-So1 serial# 2813391 The
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem. If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen. The lens is very thin glass material. You can say the lens is the "eye" of the unit. If the eye is dirty then it will not see the object. The unit needs to be opened carefully and this lens has to be checked. If any dust is collected clean it. Using the cd lens cleaner helps, but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help. If the lens is got cracked then the lens assembly has to be replaced.
You can use dry tissue to clean the lens. once the unit is opened. ------------ ------------- In most of the cases, this problem is not related to cd.But still get the cd checked in any other player too, this will confirm the fault. Also try other various cds in the boombox cd player and confirm. But if the cds not playing in other player too then its faulty cd.But this is very rare. Most probably the fault is related to boom box cd player. In the boom box cd player unit there are two main parts. One is cd spinning motor and other is cd reading lens(its also called "EYE" of the cd player).But many times the cd spins internally and does not play. If you can hear the noise of cd spin inside then its lens problem and not the motor. But if there is no spin noise in the unit then both lens and motor are to be checked. The motor is not spinning because its short/blocked or its connections are got loose. It has to be checked. The lens is not reading the cd, because its got dirty or its got cracked and faulty. The boom box cd player lens is made up of thin glass and its very delicate. Many a times dust gets collected on the lens, so the lens stops reading the cd and it do not play. Some times there is no dirt on lens but it gets cracked, if by mistake any pressure is applied on the unit or up-side down cd is placed in the tray or internal short circuit has occurred. These are few possibilities of lens not working. But in most cases its dirty lens causing this problem. SO open the tray by pressing the eject button, then unplug the unit from main power outlet, by keeping the cd tray open. Then take air blower and blow air in the unit. Please remove, if there is any cd in the tray while blowing air. Just blow air for few minutes. Then take a dry tissue and clan the cd placing tray externally and then reconnect the power and see, if that is helping or not. If the problem is same as before, then disassemble the unit and clean the lens manually by hand using dry tissue paper and then see if its helping. But take care while cleaning the lens with dry tissue you doesn't apply too much pressure on lens or any other parts. Also before removing any screw to disassemble the unit. Take a marker with you ready. Just mark the position of parts and screws before removing. If you have a cell phone with web cam in it then take a photo of the internal parts before moving any parts. Disassembly is not very hard but reassembling is not easy. So this pictures and marks with help you for reassembly. ----------But if lens is cracked internally then the lens assembly has to be replaced. If motor wires are loose then you can easily get it re-soldered by soldering machine. You can get it replaced from local cd /dvd player repair center. They have these parts with them. --------------- This should help. Thanks. Helpmech.
Posted on Aug 07, 2011
gopakumarg43
  • 74383 Answers
SOURCE: My Sony CFD-S33 CD player has started only playing 10 min of each CD
Clean the optical pickup lens, by inserting a lens cleaning disc into the player. If it do not help you, repalce the optical pickup unit. Sony sets will have special type optical picku units. You might have to contact the authorised service center for Sony at your town, to get an original one.
Posted on May 23, 2012
May 22, 2012 | Sony Cfd-s33 Cd Cassette Recorder Am Fm...
Need a relacement anntena for sony cfd-s22
Radio Shack is the only store that carries a variety of antenna's, but not sure if they still do.
Apr 12, 2012 | Sony Boom Box With CD Player & Cassette...
Sony CFD-F10 wont play cds, says no disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say "no disc".
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Feb 14, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have a sony CFD-S01 which will play commercial cd's but when a cd-r is inserted it either won't recognize the disk or it jumps constantly after appros 10 sec, any ideas?
The CFD-S01 is designed for use with CD-R and CD-RW discs. With that in mind a few things come to mind. Are the CD-R discs you are using music or data discs? There is a difference and some CD players do not get along with data discs and won't play them well if at all. Also the burn rate used can have an effect - too fast and it won't play well. If a disc doesn't play at all it might not be finalized. A disc must be finalized on the recorder it was burned on before it is playable on any other machine.
Nov 27, 2010 | Sony Boom Box With CD Player & Cassette...
Sony cd radio cassetteplayer says no disc when disc is in player
Make sure your cd medium is compatible with your Sony unit. Some cd types that have been burned on a computer may not be compatible. Check your instruction book for your Sony unit to see what types of cd medium you can use.. Also, the lens on you cd player could be dirty and may need a cleaning CLICK HERE to see the Radio Shack lens cleaner. You can also get them at may other locations like Walmart, Target, Sears, and Best Buy. Good Luck! : )
Nov 10, 2009 | Sony CFD-F10 Radio/Cassette/CD Boombox
Need user manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDE90&LOC=3
here is the manuel.
thanks for choosing FixYa
May 28, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
My CFD-Z501 won't play a disc. I get the message "no disc"
Try to use CD/DVD clening disk ($6 in Walmart). Or simply use cotton swab (Q-TIP) and 40 % ethyl alcohol (vodka) or 50-70% isopropyl alcohol (NO ACETONE), depending on your budget.
Also check if discs are inserted correctly and not damaged/durty etc. Also check your discs. Some CD-players dont accept burned CDs (copyed). I believe Sony is not the case, just a suggestion.
If cleaning wont help lens might be damaged.
Good Luck
Jan 26, 2009 | Sony CFD-Z501 Boombox
Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Mar 23, 2007 | Sony CFD-S350 Radio/Cassette/CD Boombox
Sony Cfd-s33 Cd Cassette Recorder Am Fm Radio Boombox, Working Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
