Question about Little Tikes Cozy Coupe
Cannot get the roof supports on.
The roof supports will not attach to the car body.
I found after 3 hours of struggle, that by putting a VERY light coating of vegetable oil on both the posts and the mating part, pressing down on the post and rocking them back and forth (frint and back) the posts slipped in easier.
Posted on Dec 29, 2009
    Problem Solver:
  • 6 Answers
You have to be standing up, using a good deal of force, and slowly rock them back and forth, front to back, until they pop in. They will go, but it is difficult. Good luck.
Posted on Jul 20, 2009
Vegetable oil works. The piece slips right in with a little grease!
Posted on Jun 19, 2011
Roofing how many bundles of roofing singles douse it take for a house roofed .
measure lenth x width.divide by 100= amount of squares. 3 bundles per square
Nov 02, 2016 | Cars & Trucks
Where is the inertia switch
depends on the car, usually the inertia or fuel security switch is attached to the body in the footwell under the steering wheel (in the left panel on left-hand drive car) , another place is in the engine compartment ever attached to body usually near suspension support.
Jun 08, 2016 | Cars & Trucks
2006 dodge durango that does not have a sun roof that leaks water on the Head liner and seat belt and floor when it rains or I go thru car wash? What could cause this?
I just Googled a picture.
There is a roof rack type trim on the roof.
Water flows downhill
3 possible sources:
- window trim
- windshield
- roof trim
I would be suspecting the roof trim. Determine how it is attached. Remove it. Clean the roof and all parts of the trim that contect the roof. Apply sealant in appropriate locations. Re- install roof trim.
Test
No leak!
Ta-Da!
Apr 15, 2016 | Dodge Cars & Trucks
2006 dodge durango that leaks on Head liner and seat belt and floor when it rains or I go thru car wash?
3 possible sources:
- window trim
- windshield
- roof trim
Test
No leak!
Ta-Da!
What is the best roof support system for a 2 car garage
Steel beams will need to be used if you want open space with no poles. Laminated beams can also be used but support poles will have to be added. Build a truss roof over top and do away with the flat roof.
Sep 25, 2013 | Behm Design 20 x 20 Two Car Garage Plan...
The front pillars of the cozy coupe don't fit
Ok after three hours I figured it out.
Once you have the hook in the position and all that is left is to apply pressure to press it in. Instead of using your hand like the directions and the instructional video shows. You have to put your foot in the back of the body and put your knee against where you hand is suppose to push and push using your knee with your foot in the back of the body as support. This whole body force snaps it in.
Jun 17, 2010 | Little Tikes Cozy Coupe
How to remove the fiberglass cap under the vinyl roof on my car?
The car has the entire vinyl roof attached not to the roof but a fiberglass sub roof. To remove well that's the upholstery people secret and why they charge 700. To remove and replace after the glass co. Comes in and replacing e's the rear glass. There is a patent on it and different mold for every car.
Feb 10, 2010 | 2001 Lincoln LS
HAVING A HARD TIME FINDING REPLACEMENT BODY PARTS,LIKE WINDOW TRIM,UPPER REVEAL,THE PART JUST BELOW THE ROOF LINE FRONT.
Have you tried the dealer or wholesale sites like http://www.mitsubishi-parts-dealer.com/ ?
May 09, 2009 | 1994 Mitsubishi 3000GT
Following an "incident" with an overhead garage door, roof damage was repaired and the antenna replaced by a reputable body shop, but no reception on AM band and limited FM reception on my '03...
remove the antenna and check that it is connected properly. the body work could have resulted in a poor connection.especially the ground connection to the roof itslef.
Nov 10, 2008 | Volkswagen Jetta Cars & Trucks
Rusty roof
your best bet is to have a windsheild glass removed and resealed . they will put an extra amount of silicone sealant threre to help with the leak if they can. if the leak is on the body then your going to have to have a body shop take care of that for you..
Sep 03, 2008 | 2000 Mercury Cougar
Little Tikes Cozy Coupe Logo
588 people viewed this question
Top Little Tikes Toys Experts
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
