Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lights on overhead unit on garage door opener will not go off
My craftsman 139.53990d garage door opener,the overhead lights will not go off and can not be turned off from button on inside wired keypad. This happened after thunderstorm that tripped breaker in main house panel.Everything else with opener still works including remote openers and outside wireless keypad.Help!!!!
    President:
  • 3,197 Answers
This is not too uncommon. What tripped the breaker in your house also got to one of the relays on the logic board of your opener. The only cure I know of is a new logic board.
Posted on Jun 18, 2009
Why does the overhead light on my garage door opener go off & on without any reason, day or night, even when door is not in use?
There's a gremlin living in your overhead light.....lol. The circuit board in the opener has the timer for the light. There's a component that's beginning to fail on it. Replace the circuit board.
Jun 29, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
Craftsman overhead garage door opens at random?
There is some interference created by other wireless devices within range of your garage door. This maybe a door bell, baby motor or car immobilizer. Check to see if there are any new wireless devices, it maybe someone Cole by like a neighbor. Alternatively, you can delete the existing remotes from the unit and reprogram the remotes again, this will reprogram the emotes on a different frequency and hopefully cut out any interference. Need new garage roller doors for your Perth home Think Modern Garage...
Feb 16, 2014 | managemylife.com
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Craftsman 1/2 HP garage door opener with one green and one yellow
It sounds like a logic board problem to me. I would remove the board and look for bad connections especially around that small transformer.
Aug 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open garage door
Remove the cover and take a look at the drive gear. It sounds like it is stripped.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener does not work may have beem electrical storm. unit has power model 248739
I have Sears Craftsman model 139.58778 and the remote is suddenly not working for no apparent reason. The transmitter in the garage works fine but the portable unit for the car does not. The red light goes on and the toggle switches are correctly set and match the overhead unit setting. Any ideas what is wrong? I purchased a new remote and it did not work either after being correctly set, Thank you!
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
683 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
