Question about Miele Microwave Ovens
Removing microwave facia
How do you remove the facia from a built in microwave oven (M635 EG)
  • 43 Answers
SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Posted on Feb 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: removing microwave surround
Ahh, that's one of those British brands I can't get any information about.
If you have the installation instructions, they would tell you how to install it, and it's as simple as reversing the procedure.
BUT maybe it's not too different from US models in the sense that many of its components can be accessed without pulling it from the wall, assuming it's the over the range type.
I would first refer you here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
In most cases, you unplug the oven, then remove the vent grille across the top, then you'll see a screw holding the top of the control panel frame in place.
Once that screw is out, you probably lift up and either swing forward or twist to loosen the control panel.
You should be able to access the fuse, etc. at this point.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If it's built into a cabinet, then you would have to remove the metal frame covering the area in which the microwave rests.
Be safe.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
Posted on Mar 31, 2008
mikedem7
  • 25 Answers
SOURCE: Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
  • 574 Answers
SOURCE: Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Posted on Sep 03, 2009
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
Jan 25, 2015 | KitchenAid Microwave Ovens
How to remove frame ER 629 from Miele 626 EG
First, I'm not a Miele tech. But I have worked on commercial espresso equipment and table top units.
*** The following is for information only ***
* I found this link that may help. Note that many of these table units require special tools to access. If your trying to access a panel with these special screws then removing them will probably void your warranty. Call your vendor or MFR for service.
* follow the link for more information.
Aloha, ukeboy57
https://www.bing.com/videos/search?q=miele+espresso+machine+repair&&view=detail&mid=CCE1F05D2886FF9F3826CCE1F05D2886FF9F3826&&FORM=VRDGAR
Apr 28, 2014 | Miele M625EG Convection Microwave Oven
Microwave oven is completely dead
i believe you would have to take the entire microwave caseing off to access the back of the plug
Jul 12, 2012 | KitchenAid KCMS2055SSS Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Trying to remove built in Kenmore microwave 1994 #89755?
A family member removed it while I was away. Returned home a short time later & it was outside under the C/P. Thanks anyway.
A.J.M.
Dec 30, 2008 | Kenmore 62622 Microwave Oven
I purchased an intellichef microwave from qvc. the turntable has quit working, can this be fixed or do i need to purchase a new ,icrowave?
I have the same oven and it did the same thing. I fixed it by removing the drip pan and removing 3 screws and poping the plate, the screws are holding down, up you won't be able to remove it all the way out, then clean out all the gunk that has built up in it put plate back in place and screws back in and hopefully that will be enough to get it going again. It worked on mine.
Dec 26, 2008 | Microwave Ovens
Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
Mar 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
