Qss 3001 noritsus machine
Arcnet communication error
3 Suggested Answers
SOURCE: We getting the problem in
close cover unit
Posted on Mar 22, 2011
alpug
  • 1961 Answers
SOURCE: 2 arcnet pc130e cards do
Hello!
When you see a green lights on arcnet pc130e it means it has communication between your pc and router (or modem). Data is being transmitted. So, it means the device is working properly.
The other arcnet without the light, perform the following:
1. Try replacing the lan cable to make sure that no open wires or no faulty connectors on both ends. You should see a green light if the lan cable is the problem.
2. Check on both ends of the lan cable. make sure it is inserted properly on the lan port. You should hear a snap sound as it locks up.
3. Make sure the lan port on the router is OK, you should try the other port and see if the green lights appears on arcnet.
4. Connect this arcnet pc130e to a PC with working arcnet. If the green lights appear, it means you only need to reinstall the driver. If no green lights, this device is faulty and needs to be replaced.
Good Luck!
Please accept if this will help you.
Posted on Sep 23, 2011
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
I have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Nov 10, 2008 | Ricoh Aficio 450 Copier
MOTHER BOARD
see they or correctly plugings if they or correctly plugings once again u install drivers of digital machine if the process not started then format the system and install driver of digital then u can start process.
Jul 02, 2008 | Intel Computers & Internet
Error 3001
I have brand new DV600E unit for sale, send me email for more information.
Apr 30, 2007 | JVC BR-DV600E VCR
Computers & Internet Logo
David Payne
David Payne
