Konica minolta bizhub c450 error code cd366 - Office Equipment & Supplies
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Problem with the Konica Minolta
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Posted on Feb 16, 2011
  • 77 Answers
SOURCE: Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Posted on Nov 28, 2012
How i can rest error code c-d231 on bizhub c450
CD231 in Bizhub C450 come due to missing of DIMM memory board in Fax board.
in service mode(Utility-counter-Stop-00-Stop-01) -system2-option board-unset the Fax1 and fax2 and re-start machine .
Jul 03, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
61 people viewed this question
jasbo
jasbo
