Question about Miele Microwave Ovens
Miele M635 EG Facia removal
How do you remove the facia?
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
May 14, 2014 | Miele M625EG Convection Microwave Oven
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
Nov 10, 2013 | Goldstar MV-1515 Microwave Oven
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
Some power but not operating
Check out with a multitester whether the control panel switch on the power towards the high voltage transformer NNB disconnect the high voltage transformer for this test. if not the relay on the electronic controlle device is broken and the panel needs replacement. check also the 3 safety switches on the door for proper operation. mind the power it is dangerous.
May 10, 2013 | Sanyo Microwave Ovens
The numbers are worn off. Can we just replace the
yes you can its called a membrame switch but you will need to take the facia off and connect it to the main control pcb so you need to find the spare part first not all are available as spares
Oct 01, 2009 | Panasonic NN-T964SF Microwave Oven
Replace sping in door model r 1611
The spring is probably OK, but tab it mounts on may have broken. To remove the door, pry out the little cover (~1.5 in by 1 in) on the inside of the door by the upper hinge. Then you can lift the entire door off the hinges (with the door open). Then you have to pry the inner plastic fascia (faces the cooking cavity) that surrounds the glass. Once that is off, you can see where the spring is, or was. My tab had broken, but I was able to mount a small bolt thru the endplate of the door (so it doesn't show when the door is closed) which I could mount the spring on it. There isn't a lot of clearance on the outside, so a low profile head on the bolt is better; otherwise, the head will catch on the edge of the control panel as you try to close it. I put 2 nuts on the inside, with locktight, and put the "hook" of the spring around the bolt in between them. I will admit, I had to drill 3 holes before I got an acceptable amount of tension on the spring (I kept having too MUCH tension). For some reason, putting the bolt approx where I thought the tab had been resulted in too much tension. I suppose I could have stretched the spring some instead of relocating the hole and bolt. Push the fascia back into place, remount the door on the hinge, and replace the little cover. Hopefully the door will line up OK, the latch will catch and release as it should, and the interlock will be released as it should be when the door is securely closed (and interior light goes out). One other caveat, I am not a professional, and the door does need to "seal" or I guess all those evil little microwaves can escape and emulsify your brain, or whatever would happen. I will not be held liable if there is leakage.
Apr 23, 2009 | Sharp R-1610 Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
We are house sitting for friends. They have a Miele Classic, wall mounted combi oven. It has a single dial at the top left of the silver facia. To activate the microwave, I turned the dial one click...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Please reply back with your brand and full model number.
May 11, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
