Question about Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook
Sd card stuck in slot cant remove it - Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
Were do i put my sim card in a rca tablet
There should be a slot along the side, you may need to remove a small rubber cap they sometimes put on top of the sim slots. make sure you insert the card the right way in, you should feel a click if card is seated properly then put the rubber cap back on.
Oct 02, 2016 | Tablets & eReaders
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
Feb 06, 2016 | Nextbook Tablets & eReaders
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
How do i get my micro sd card out of the slot on my asus memo pad, its stuck and i cant see it
The card reader slot is shorter than the memory card itself, so it sounds like you didn't put the SD card into the card reader but rather, into some other kind of slot. If you cannot see the card at all, try straightening a wire such as a large paperclip or something and try using a flashlight so you can see to try and fish the SD card out. If you can't do it, you will have to go to the local computer store for them to try for you.
Apr 26, 2015 | ASUS MeMO Pad HD 7
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
How do l mount a sd card on my zeki tablet TBDG734B
Mounting is done automatically by the device in most
Android tablets.
For an Android, all you have to do is insert the SD card in the slot and it will be mounted automatically. If you want to remove the card, though, you need to *unmount* it. You can unmount in Settings>Storage>External SD card and will see the unmount option listed below it. Touch it and then you can remove your SD card without the possibility of corrupting the files.
Apr 17, 2015 | Tablets & eReaders
Where does the SD card go on 9" ONIX tablet?
It has a micro sd card slot on the side its very thin slot.
Aug 20, 2014 | Tablets & eReaders
Micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Jan 06, 2012 | ViewSonic ViewPad 7 Android Tablet
How do i load pictures from a sd card into computer
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
Sep 24, 2009 | Gateway CX200S Tablet PC
Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook Logo
27 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
