Question about Canon Elura 70 Mini DV Digital Camcorder
Cannot install cassette
Removed cassette that was just used then a little later tried to re-install but the camera would not move the cassette down and instead ejected the cassette. battery is fully charged and all other functions have been working correctly
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
  • 3 Answers
SOURCE: remove cassette
Try inserting a cleaning cassette. There may be something on you video heads and your camera is protecting itself from damage. If it wont let you play the cleaning cassette consider using some compressed air via a can of "blow-off" or similiar product. If that doesn't change anything send it in for repair.
Posted on Sep 22, 2007
  • 6 Answers
SOURCE: cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
SOURCE: Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Posted on Jul 08, 2008
SOURCE: Mini DV Cassette won't come out
I AM HAVING THE SAME PROBLEM. HAVE NOT USED THE CAMCORDER FOR A YEAR AND A HALF. IT MECHANISM MOVES IN AND OUT BUT WILL NOT OPEN UP TO PUT A TAPE IN. VERY FRUSTRATING.
Posted on Oct 19, 2008
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
Memory card is locked
what kind of Memory card is that SD/Micro SD? or what so ever, normally all MMC have lock option on it, try following these steps:
  • take out the memory card look on the left hand side of it and it might say in little letters lock and there's a little thing that moves up and down and then move it up.
  • The switch / notch works in same way as the notches on compact audio cassettes and videotape cassette tapes or floppy disks. A closed or covered notch is writable, while an open notch (or removed tab) is protected.If the switch becomes broken or falls off then the card will become a write-protected ROM card and no longer be writable. A possible troubleshooting solution would be to apply tape over the notched area (avoiding the connectors and the other notch) to configure the card in a permanent writable state."
Pleasenerdierob.jpg see attach picture for your reference
May 30, 2011 | Cameras
I have a JVC C-P6U Cassette Adapter,I have not used it for some time as there was a cassette inside I put it in my TV and played the tape which was great when it was finished I wanted to remove it and play...
the adapter is probably jammed you may need to use a little force for the switch also a little force to try and pry it may work without damaging it. please let me know if this helps if now i will glady do more research on it for you but this is what i found when i was looking up the adapter issue.
Mar 14, 2011 | JVC CP6U Adapter
My camera keeps saying "the card is locked"
hi
take out the memory card look on the left hand side of it and it might say in little letters lock and theres a little thing that moves up and down ... move it up...
check out the below picture......
its the tape notch on a SD card
good luck
Jun 16, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Minidv reinsert cassette
THIS IS A BAD TAPE TRANSPORT PROBLEM
Feb 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Problem with loading cassette
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 13, 2007 | Canon Optura 200MC Mini DV Digital...
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
My Cassette Tape Deck is Jammed Open - Help!
Glad to hear that you got the unit working. One thing you might want to do now that you resolved the jammed problem, to avoid future problems, is with the cassette deck open, look in to the opening and check all the metal parts for any signs of being bent or twisted, even slightly. There is a reason that the door has a spot marked "push door shut here". Pushing it anywhere else will usually bend something. It may be working now but who knows. Usually when you force the cassette mechanisms on the little camcorders you bend something and sooner or later it will come back to haunt you. Now you can open and close it so it would be an easier fix. If you find anything bent you will need to carefully straighten it. Believe me, a little time spent now will save alot of grief later. Perhaps your father-in-law would have the skills to check it and straighten any bent parts. Even if you don't find any problems you will at least have peace of mind knowing that everything is OK. Good luck.
Jun 04, 2006 | Panasonic PV-GS2 Mini DV Digital Camcorder
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Apr 10, 2006 | Canon ZR10 Mini DV Digital Camcorder
Canon Elura 70 Mini DV Digital Camcorder Logo
19 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
