Question about Continental CE-AC75271 Ductless Mini Split System Air Conditioner
E3- DISPLAY- HOW CAN I FIX IT ON AUX AIRCON - Continental CE-AC75271 Ductless Mini Split System Air Conditioner
    New Friend:
  • 84 Answers
It is an internal fault,so leave it to the technicians for your own safety
Posted on Apr 23, 2014
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
Aircon not cooling, aux fan not turning, fuses OK heating Ok ,system has been regased
If the fan that cools the condensor is not working then the aircon will not work .
Dec 02, 2012 | 1995 Mercedes-Benz E-Class
Error Code E3 displayed on Samsung wine cooler model RW13EBSS, even after power off and reset.
"E3" on display for upper zone - error of DC
electric fan for upper zone.
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to each other. E3 went away and the cooler is working as it should now.in
Jun 15, 2011 | Refrigerators
I have a Daytek 12000BTU airconditioner that is displaying an error E3. What is this error and what spares can i buy to repair this problem.
E-3 means indoor fan motor malfunctioning. You can check by manually rotating motor, if hard, Check for bearings and replace it or replace fan motor.Is it helpful?
Jan 06, 2011 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Our Mitsubishi FDC506HES ducted air conditioner keeps shutting off on hot and cold after about 10 minutes and flashes and the comes up with the error code E3.It will heat for those 10 monutes before it...
Try to reset the error by disconnecting the circuit breaker for 10sec. and "on" again then operate the unit. But if wont work may there some parts that are defective that trigger the error E3. Replacement of pars is needed for this problem.
Sep 22, 2008 | Mitsubishi Heating & Cooling
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Continental CE-AC75271 Ductless Mini Split System Air Conditioner Logo
282 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Tim Whalen
Jay Finke
Jay Finke
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
