Lg flatron m2762d
Hi i have a picture for about 30sec and then the screen goes black/ blank. Sound is ok and i can change channels
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Posted on Sep 28, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
  • 140 Answers
SOURCE: LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Posted on Jan 15, 2009
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
My lg 27 M2762D have black screen with normal sound, and after restarting tv ,screen is normal for while and return to black
Could you solve it? I have a similar issue
http://www.fixya.com/support/t19795450-lg_27_m2762d_black_screen_after_random
Jan 27, 2012 | LG M2762D 27 LCD TV
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
MY LG LCD TV PICTURE DIED
Hi...there,
Wow! You guys...must had watching a really....HOt sizzling movie to make it overheating. Hehehe...
Your inverter are fried, need to replaced a new one. If you still under warranties asked LG to send you a replacement. Have a nice weekend!
Oct 04, 2008 | LG Flatron L1710S 17" LCD Monitor
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
