Question about Kitchen Ranges
What year model is Roden Rambler 64
Need to know year model
Where is the antenna switch to turn on the antenna in my 2015 Holiday Rambler Admiral
I don't know if your model has the same equipment but on page 104 of their manual it shows you how to operate the antenna.
http://www.holidayrambler.com/resources/media/manuals/2016_Admiral.pdf
Mar 13, 2017 | Holiday Rambler RVs
Wont install booster brake and vacuum on 1965 amc rambler and Hydraulic steering
I saw one at RockAuto.com. Well known, great online parts store. Their catalog makes it easy to look at everything they have in stock for your 1965 model. Best thing about RockAuto is they usually have the lowest prices on everything. Do-it-yourselfers give them a lot of business.
Oct 07, 2016 | AMC Cars & Trucks
I have a 1963 rambler ambassador and I tried to leave and that is when I notice my car wont go into drive but it will work in reverse fine what could it be?
1963 rambler
Laticia, Sound like your Rambler Flash O Matic transmission needs internal work/rebuilding. Have checked by a good tranny shop. No drive gears could be clutches, valve body, pump,bands,etc.
Check the attached links, transmission kits and replacements. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
AMC Transmission eBay
http://www.fatsco.net/borg-warner-35.html
T35 transmission parts Borg Warner T35 transmission parts
Apr 06, 2016 | Cars & Trucks
I have just bought a tolbot express rambler with no manuals can any 1 help me to find 1
check net for downloads, ebay sometimes have manuals for sale. good luck
Mar 03, 2015 | Cars & Trucks
64 rambler, classic 6, valve settings
.012" INT and .016" EXH (source is AMC forum on line.)
Aug 18, 2012 | Cars & Trucks
You are facing a closed garage containing four cars parked side-by-side. Using the information below, determine the order in which the cars are parked, as well as the make, year, and color of each car and...
hey iv worked out what i can but its impossible to work out the year for the ford?
1. RAMBLER 1971 PENNSYLVANIA BLUE 2. FORD ???? NEW YORK GREEN 3. BUICK 1979 CALIFORNIA RED 4. PLYMOUTH 1960 OHIO YELLOW
Nov 29, 2010 | Toys
Power steering box that will interchange with 1965 Rambler V-8
ramblers were a mixture of the" big three" back in the '60s you might see if a steering box from a dodge ram series pickups or ford f series pickups may fit. also,check closely on the steering box for a casting number,parts suppliers use these numbers as a cross reference to match other steering boxes to your application.
Jan 20, 2010 | AMC Cherokee Cars & Trucks
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
Setting the clock on my Roden Europa oven
I have instuctions if you would like a copy Regards ian@bscprojects.com.au
Aug 30, 2008 | Ovens
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
