I,m just doing my thing - Audio Players & Recorders
    Master:
  • 388 Answers
Good on you!
Posted on Apr 16, 2014
How do I unblock websites in schools
Best thing is to ask the teacher and see if this is the right thing to do, if you don't want to ask the teacher, then you shouldn't be trying to unblock websites. Do what is right and things will go well with you soul.
Mar 02, 2015 | Cars & Trucks
What wiil magnetic things do with things made from metal
most of the time if you put a magnetic thing on to metal it will stick. the magnetic thing will not stick to plastic or wood unless there is another magnetic thing under the plastic or wood.
Oct 08, 2013 | Computers & Internet
How do living things interact with farmland
Living things do interaction with farmland as making it as their means of resources for survival. It refers to the ecosystem of the living things. A farmland has a lot to offer among living things that will greatly helps them to live.
Nov 10, 2010 | Microwave Ovens
What do i do if the thing that spins the disk is not spinning?
see if there is anything stuck in the spinning thing any little thing
Feb 15, 2010 | Sony PlayStation 2 (PS2) Console
Which is what I do to write the code P0420, as do I fix it? I change it?
So what is causing my P0420 code? There are a number of things that could be causing this p0420 catalyst efficiency code. The most common thing is the catalytic converter itself is no longer functioning properly. The other likely thing is the rear O2 (oxygen) sensor is no longer working properly. Other things could include exhaust leaks, damaged exhaust pipes, damaged O2 sensor wiring/connectors, plugged catalytic converter, etc.
OK, so I want to diagnose things, what do I do next? The easiest thing to do first is a visual check of things. Visually inspect the exhaust system for leaks, check the catalytic converter for dents, holes, severe discoloration, and check for a rattle inside. If any of those syptoms are there, the converter likely needs replacement. Then, visually inspect the downstream O2 sensor (behind the converter). Check for broken wires, obvious faults, etc. If all that checks out, you'll want to check the operation of the O2 sensor. To do that, you'll need access to a scan tool or oscilliscope. Check that the waveform is pretty steady. If the reading fluctuates then the sensor is likely bad and will need to be replaced.
On some vehicles such as some Subaru models an ECM reflash will fix the problem. As you can see a P0420 can be caused by many things, so if you have any doubts as to whether you can fix the problem yourself, please seek the advice of a professional technician. Good luck!
Answer found @ www.p0420.com
Jan 23, 2010 | 2002 Jaguar X-Type
Panasonic Plasma TH42PZ80U - Picture Reset Mode issue
don't do the latter, just do the take-it-to-the-tip thing.
Oct 02, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
12 people viewed this question
 Grubhead
Grubhead
