Question about Teac Audio Players & Recorders
Amplifier keeps going on to standby
Turn power on press standby and i clicks and gose back on standby
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teac Master
  • 924 Answers
Your amplifier more than likely has DC Offset, a damaged amplifier. If you are interested in having your Teac repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Posted on Aug 04, 2015
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
The amp won't power up. The cord is is, the power is on, but when I press the Standby/On button, the MP3 LED blinks a few times, then it goes off and all the LEDs, from the protection, speaker A, B and so...
Hi... If all the speakers are connected properly then I would say, there is a failure in either the power supply filtering caps or one output has failed and it's going into Protect mode to keep from frying the speakers
It will require service at that point.
Aug 21, 2010 | Cambridge Audio Azur 650a 2Channel...
1988 pontiac grand prix less power
2.8l were known for fuel injectors, vacuum leaks up by the throttle body, and there is also the idle speed control, but sounds like injectors or vacuum, double check your wires on the coils too
Jul 23, 2010 | 1988 Pontiac Grand Prix
ITS ON STANDBY MODE & NOT ABLE TO GET ITS DISPLAY
Try this, not sure if the same would work for ya.
Swich off the amplifier.
Prior to the process check the wires connecting the speakers are not creating a short circuit which is apparently putting the amplified into a standy mode.
1. Press the "A" "B" and power key all at the same time and hold on to it.
2. The amp will go into a reset mode and will keep blinking till it gives a normal "click" sound and the amp turns on.
3. this process would take about 2 - 3 minutes.
4. You may then release the buttons.
5. If it goes into a standby mode again and does not power on, or the standby keeps blinking, get assistance from the engineer.
6. Once it is on, you shall need to do the resetting of alll the configurations done earlier.
Hope it works, it costed me 3k to get the job done.
Nov 12, 2009 | Denon AVR-1603 Receiver
Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Nov 05, 2009 | Technics Audio Players & Recorders
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
Receiver stays on standby mode
Receiver either just stuck or held or having problem in amplifier output area.
Try to unplug it from AC outlet for couple of minutes and replug back in and power up, if works, fine and if does not, take it to local repair shop as it might requires some parts replacement in amplifier out area.
Feb 10, 2009 | Insignia Audio Players & Recorders
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
138 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
