Question about Cuisinart Toaster Ovens
Cuisinart toaster over TOB-40 clicking noise while baking
My new Cuisinart TOB-40 toaster oven makes intermittent clicking noise that lasts for about 7 seconds every minute or so while baking. It is very annoying. My daughter;s does not make any noise while baking. I returned one last week because of this, and now the new one does the same thing. What gives?
  • 5 Answers
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
  • 30 Answers
SOURCE: CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Posted on Dec 30, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Posted on Jan 11, 2009
SOURCE: Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Posted on Mar 14, 2010
SOURCE: Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Posted on Nov 10, 2010
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Why does Cuisinart TOB-40 produce steam and condensation on the glass door when toasting?
The bake/toast compartment is almost air-tight, creating an adequate seal to produce steam/moisture when the heat is applied to the water content of the food placed inside.
Mar 23, 2011 | Cuisinart Toaster Ovens
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
WHY CAN'T I BAKE A FROZEN MARIE CALLENDER CHICKEN POT PIE IN A TOASTER OVEN? (THE DIRECTIONS SAY I CAN'T.)
I do it all the time. It works just fine. I wish I knew why they said not to. I didn't read that on the package until I had done it a few times. I guess what you don't know won't hurt you.
Apr 25, 2009 | Cuisinart TOB-30 Toaster Oven with...
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
What is exactly a toaster oven?
A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
255 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
