Question about Energizer Eveready Utility Lantern Uses 6V Lantern Battery
How to install a new 6v battery into dolphin torch
How do you install 6V battery into Dorcy luminator
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
Oct 28, 2012 | Dorcy International p6V Floating Luminator...
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How to unscrew a very tight new plastic torch from its base
Looks like the top unscrews. Unscrew top and remove lamp to expose batteries perhaps.
Oct 18, 2012 | Sport & Outdoor - Others
How long to charge my Draper 6V rechargeable battery stock No.55950?
Should recharge in six hours or so, I don't advise leaving it charging more than 18 hours.
Aug 18, 2012 | Tools & Hardware - Others
I have bought a new 6volt battery for my dolphin but can't work out how to replace it.
The bezel (the circular portion on the front of the flashlight that holds the bulb and lens) will unscrew. The old battery should slide right out.
Hope this helps.
Apr 07, 2011 | Energizer Eveready Utility Lantern Uses 6V...
I bought a brightstar 2206 lantern torch and i don't seems to able to locate the battery location in order for me to replace the new batteries
If your unit looks like the one in the link I would say it is a 6V battery that sits just under the light. unscrew the light and it should come out.
here is the link
Feb 16, 2011 | Garden
How do i open eveready dolphin torch for battery
You need to twist the black bulb end off in the direction of the arrow labeled open. The best way I found was to place the yellow end between my legs to hold it in place.
Sep 23, 2010 | Camping, Backpacking & Hiking
How do I open an Eveready Dolphin MINI torch for fitting batteries
twist the top of the torch, the model I had was with 2D batteries.
Aug 10, 2010 | Camping, Backpacking & Hiking
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Logo
64 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
NicK Hale
Level 1 Expert
Tom Chichester
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
