I have an acer laptop and the os is vista home premium . the problem is that wen i open the c drive of my computer then after some time it hangs and task manager shows cpu usage 100%
  • 41 Answers
There might be some issues with your hard disk,try to do a Hard disk drive self test.If you want any further support, a technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
I'm trying to fix an Acer Aspire 5102wlmi laptop for my friend. Originally the laptop came with Windows Vistya Home premium. He told me that he bought the laptop second hand and Windows XP was...
I THINK IF U GOT THESE OS ALREADY INSTALLED HAVE U GOT ENOUGH SPACE TO CARRY ON WITH THE INSTALATION ,TRY FORMATTING UR DRIVES AND TRY SEVICE PACK 2 IF AVAILABLE ,WHY DOES HE WANT ANY OTHER IF U GOT 7 ITS THE BEST OUT SO FAR
Jan 10, 2011 | Computers & Internet
My vista hangs al the time
A faulty driver is most likely the cause. Have you intstalled any driver or software just prior to the problem occured for the first time? If so, uninstall it in Safe Mode. If you need instructions, let me know.
Apr 12, 2010 | Microsoft Windows Vista Home Premium...
Acer 5315 wont boot up
Try to install back the OS, that will tell if you have an hard drive issue.
Thanks
Kindly rate the answer
kevin
Jul 07, 2009 | Acer Aspire 5315 Notebook
ACER 5630-6288 Win Vista Home Premium Admin Password forgotten
yes there is
login with ur normal user profile
go to run>>type cmd
in the black box...
type net user administrator
it will give u options to change the pwd for administrtaor
May 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5738g hangs
Hi.
I too have also bought the aspire 5738.
Mine was also hanging, eventually i sent it back to acer.
The mother board was replaced as it had a faulty north bridge on it.
If your unit is still in warranty get it done as soon as possible.
May 07, 2009 | Acer Aspire 3610 Notebook
Acer aspire 5315 shuts down
pls check the the power cable and battry states and after thye are working .ok fine next setp
formatted the laptop usenig a win xp cd .............and check it same times vista need high configartion .......ok
Apr 01, 2009 | Acer Aspire 5315 Notebook
Reinstalling Vista and Acer Tech
The restore disk should be available from Acer Suppport here https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer if they no longer support it then you should be able to get it from restoredisks.com
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
Stop: oxooooc1f5
The error "Stop: oxooooc15" is usually caused by the new vista SP1.
Try the following
Start>Programs>Accessories>System Tools>System Restore. Restore you laptop to before you had the problem or error.
You can also try the solution from this article by Microsoft
http://support.microsoft.com/kb/946084/en-us.
Jan 09, 2009 | Acer TravelMate 5520 Notebook
Acer Extensa 5430 Hangs
VISTA HAS PROBLEMS WITH CERTAIN GRAPHICS CARDS AND WITH JAVA-SCRIPT -APPLETTS, CHECK AND SEE HOW MUCH MEMORY YOUR COMPUTER CAME WITH, I HAD A CUSTOMER WITH THE SAME PROBLEM AND VISTA DEMANDS A LOT OF WHAT IS CALLED SYSTEM-MEMORY FOR SIMPLE THINGS THAT THE COMPUTER DOES. AFTER UPGRADING THE MEMORY AND THE HARD DRIVE IT STILL PERSISTED SO EVENTUALLY SHE BACK-GRADED TO XP WITH SERVICE PACK 2, BUT IF YOU WANT TO KEEP VISTA GO TO MICROSOFT UPDATES AND SEE IF THEY HAVE A UTILITIES SUITE THAT CAN HELP WITH THIS PROBLEM. KEEP ME POSTED JON T
Dec 07, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
