Question about Kenwood Radio Communications
Trying to reprogram a TK8180H-K but the screen says !Use SJ-180! when I try to read/write to it.
Im using KPG-96 to program the radio and the computer says there is a COM port error after the unit displays !Use SJ-180! . The COM ports have been set and the test function works so the COM poshowed the cable is fine. Should I be using KPG-89D? Or have the radio been locked out or something?
    Problem Solver:
  • 5 Answers
Yes, You should be using KPG-89D or KPG-89DN.
Posted on May 19, 2014
Neto
  • 123 Answers
SOURCE: Having Trouble Receiving Through"TPL"
Are you sure that you are using the exact RX Frequency? is the radio in 25Khz if this radio is working on 12.5Khz with the IF filters changed to work in narrow band (12.5) could happend this.
Do you know if the repeater is on parameters mostly of the cases when an over modulation is received this will cut the PL modulation for short periods.
If the radio transmit over modulated could "erease" the PL modulation for short periods.
I think this radios should be checked all the Tune parameters to make sure is ajusted properly.
Good luck
Posted on Dec 18, 2007
  • 41 Answers
SOURCE: Kenwood radio TK270G
The Radio you have is probably an older version, in this case you will need KPG56D. the other possibility is that the software you have is dos driven if this is the case then you will need to install the software on a slower machine with DOS 6.22. I use a pentium pro with windows 98 to program most of my kenwood radios. you will also have to disable any virus software and disable any TSR files on the machine in order to program the radio. The windows base programs don't have these quirks. take a look at your software and let me know what happens.
Pat N5SLI
Posted on Nov 11, 2008
  • 13 Answers
SOURCE: Marconi 2951 radio test set vintage
possibly a power supply problem - check current drawn from the power line compared with your other 2951. any disturbance in power supply voltages can kill the afc/pll in older service monitors. if you have the manual check the ps voltages
Posted on Nov 30, 2008
SOURCE: GP300 Radios
I recommend you **** can the USB cable and get a RIB and Rib cable. The GP300 Motorola software is available online for free (I can give you the web page address) and works just like the real Motorola software. I have programmed at least 20 GP300s with it with no issues. A RIB is the only way to go. Everyone has nothing but trouble with USB cables. Particularly with newer radios like the CP200.
Posted on Jan 10, 2009
  • 9 Answers
SOURCE: unable to program tk-3207
hi, all i can think of is- A, the computer is way too fast for the program you are trying to run, what you need is a really old slow computer or B,
check the COM port settings on your computer.
click start, right click on my computer, click properties, then click on the hardware tab, then device manager.
then there will be a 'Ports COM &LPT' just make sure the com port number is the same one as you are using on the software. Hope this helps.
Posted on Sep 10, 2009
TK 3300 won't field program
try getting a tech support agent from kenwood to help out they should be able to walk you thru it, our company deals with Motorola and Vertex, so im not too familiar with the Kenwood specs. http://kenwood.com/
Mar 15, 2014 | Kenwood Tk-2300 & Tk- 3300 Radio Software...
Can't program tk 3402u16p with kpg 159dn software
try KPG158D two versions of radio, two versions of software
Feb 14, 2014 | Kenwood TK-3302U16P
Join software group download yahoo
The software program is KPG-35D and you need a cable that is KPG-36. I can't help you with the software because it is copyrighted by Kenwood. You should try looking in the Yahoo Groups section for a programming group or Kenwood group. Many have found the road to enlightenment doing so (if you get what I mean).
Oct 04, 2013 | Kenwood Kpg-35 V2.00 Programming Software...
I can't program a tk 2200l with my pc
Hi Gilbert,
Firstly, what operating system (OS) is your PC running on?
Check the Software disc for the OS that can be used on and version of the OS.
If this is incompatible, then that is what's causing the problem, also if your OS version is correct, you may not have all the drivers available for the software to run successfully, so you'll need to download these.
If this is not the problem, then you have a software problem on the disc itself, but that would be unlikely, as the disc is actually starting up OK.
Occasionally, the Software disc may have a defect, which may cause this, to find out if this is the problem, you need to download, or if your OS on your PC has a CD/DVD checking program, you can run this with your Software disc in the drive to check it for errors.
If errors are found, but not able to be fixed by the program, you will need to buy another copy of the software disc.
But there is another way of obtaining the required software, by downloading from the internet, and this is how to do it:
Join yahoo group specific to your radio Make/Model, the team there have a great deal of advice and info and you can download manuals, diagrams and software (if available) and other goodies for your radio, all of this is free.
I hope you found this information very useful.
Warm regards,
Peter
Mar 06, 2013 | Kenwood Kpg-88d V1.32 Programming Software...
Kpg-49d and error please check radio type
Hi Ad,
The best advice I can give is: join yahoo group specific to your radio Make/Model, there you will obtain all the info you require plus you can download manuals, diagrams and other goodies.
I hope this helps you.
Regards,
Peter
Jan 30, 2013 | Kenwood Kpg-49d Radio Software
Cant program my kenwood tk480
Hi Manaf,
There is a solution to your query.
Join yahoo group SPECIFIC to your radio Make/Model, the people there will help you to get the required software, if available.
Joining is FREE and you can download manuals, schematics and software.
I hope this helps you to solve the problem.
Cheers,
Peter
Dec 31, 2012 | Kenwood Tk480 Fm Transceiver 800mhz Ltr...
I need to rebanc my pro 96 and bought the programming cable and driver software item 20-047 (or 200-0047) and trying to find the driver for my computer and the users manual; neither of whic are on the cd....
Radio Shack no longer sells the frequency software for this scanner. the drivers for your computer are on the cds you have so hold on to them they also are no longer available. radioreference.com may have the software for programming
Jul 16, 2010 | Radio Shack Pro-96 Scanner
HI I'm seeing a different software number...
See: http://www.nielsoncom.com/kenwood/TK-270-370.pdf ( KPG-56D )
One thing you might try is programming off the front panel if "Field Programming" has been "enabled" in the software
See: http://www.repeater-builder.com/kenwood/field-programming-tk-x70.html it's slow coming up but interesting.
Is the transfer cable USB or 9 pin? I know I have had problems with laptops and had to go back to a desktop and it would work fine. I know some of my Motorola programs I have to use a old slower computer because the computer's speed. The new computers won't work with some of the older radio programs. I know my Yaesu VX-7 has the same problem with uploading, I'll get it out today and see what I did to fix it...
Nov 04, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio Communications Logo
223 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
