Question about Microsoft Windows 7 Ultimate for PC
Windows task manager a program is slow how can i fix it ?
Windows task manager a program is running slow how can i fix it and improve the speed in which the program responds and preforms?
  • Tech Master Apr 16, 2014
    i have found a solution in youtube check it out
    New Friend:
  • 3 Answers
Clear prefetch, cokies, disk clean up for C drive may help you.
Posted on Apr 29, 2014
My RPC file is missing and have no bu windows xp pro cd
Start by cleaning the Computer OS: Use freeware CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will clean the junk from your HDD. In the TOOLS section, STARTUP section, Disable ALL unnecessary Startup programs. Uninstall ALL Toolbars, they are killers on browser speed. Use freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL scan, delete ALL results, reboot. In Google Chrome open settings, Extensions, disable/remove ALL unnecessary Extensions. Open Control Panel, Internet Explorer, Programs tab, Manage Add ons, Use this procedure to disable/remove ALL unnecessary Add ons: http://support.microsoft.com/kb/883256 ALSO more tip for Windows XP speedup: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer Run this procedure to fix files.. sfc /scannow: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/system_file_checker.mspx?mfr=true Do ALL your Windows and Desktop manufacturer's Updates, make sure they are current.
Mar 08, 2013 | Computers & Internet
My pc speed is too slow. sometime it hag very much .please i request you to give mesome solution
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 07, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
FIRE WAL FORTINET FG20C
adding more computer ram is the best solution for speeding up a computer
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
however there many other processes which can help speed up your computer
try uninstalling a few unnecessary programs click start control panel add remove programs/uninstall programs this will vary depending on your operating system
then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive
do not do anything while the chkdsk utility is in progress any input might damage your hard drive
another way of doing this is
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then click start all programs accessories system tools defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer (ticking over) you might have virus slowing your computer also select users you will see who is using your computer
this will free up space and speed up your computer although installing more ram is the best option of speeding a computer up also there are many freeware tune up programs on the internet which can help speed up a computer
download a good registry cleaner
http://download.cnet.com/ccleaner/
http://majorgeeks.com/download.php?det=5804
Cleanup Assistant is a set of over 20 tools designed to help you increase your computer's performance, clean your disks and protect your privacy. Cleanup Assistant runs on Windows XP , Windows Vista and Windows 7, on both 32-bit and 64-bit versions.
hope this helps you
Apr 17, 2012 | Computers & Internet
Tmobile mytouch Q 4G Slide....running very slow not letting pull up dial pad battery running hot and running out fast freezing up internet not working alot needing to restart the phone all the time
  • Close unused programs by accessing the Task Manager on the device. According to MobileTopSoft.com, Windows Mobile devices use a feature called "Smart Minimize." This software simply minimizes a program when you think you might have closed it. Thus, the device becomes slow because too many programs are running. Closing out programs via the device Task Manager should be completed daily.
  • 2Clear the temporary files from the device. Storage on a Windows Mobile device is at a minimum, and it's important to keep the phone cleared of any unnecessary data, such as temporary Internet files. To complete this task go to Internet Explorer and access "Menu," "Tools" "Options" and finally "Memory"; delete the files here.
  • 3Avoid overloading the device with unwanted programs. Programs take up storage space on your device. By taking caution when downloading programs and removing unwanted programs, you will minimize the amount of storage taken up. This will reduce the slowness of the Windows Mobile device.
  • Sincerely. G-d bless you
    ERNESTO CUADRA
    mANAGUA, NICARAGUA
    Dec 15, 2011 | LG Cell Phones
    My laptop is operating very slowly!I dont understand the problem!
    1. First of all download and install CCleaner, it is free.
    Here is the link http://www.filehippo.com/download_ccleaner/download/1d59b13e3d0824a0c054077615cab5c3/
    2. Run the exe and then follow the instruction to install the ccleaner.
    3. After opening the ccleaner, select all the check boxes inside the cleaner tab.
    4. Click on Run Cleaner.
    5. Click on Registry in the left side tab.
    6. Click on scan for issues, then click on fix selected issues. Click on no when asked to back up.
    7. Go to Tools Tab and then click on startup tab, Now uncheck all unnecessary and unknown application from being startup.
    8. Restart ur computer.
    Check now the performance.
    If you think there is any virus in your pc, then scan your pc with ESET NOD32 On demand scanner or install Quick Heal. If you want free antivirus then download and install avast home edition 5.0 and register for 1 year free license. (WWW.AVAST.COM)
    ** After doing all this, if u further want to improve ur system performance then tell me the Operating System installed in your system then I will tell you how to improve.
    Jan 31, 2011 | Computers & Internet
    How to you speed up a slow moving HP Pavilion a706n desk top
    try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
    click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    defragment your hard drive will speed up your computer
    scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
    this should speed your computer up
    also you could increase the size of your RAM random access memory
    hope this helps
    Jan 18, 2011 | HP Pavilion a706n PC Desktop
    Very slow start up of computer, very slow to open any folders, slow to start up aol or msm, is this a hard drive problem, if so how do i reprogram it
    1) Check your harddisk utilisation isit almost full or not??if full try to delete somefiles and check the performance.
    2) Open task manager and check which program using more memory.
    3) Check your task manager which all program running in background which can also reduce your pc performance....
    Sep 17, 2010 | Maxtor 40GB INTERNAL 3.5- IN ATA133 HDD...
    Processor running at max!!!!!!!!!
    having too many desktop items can cause a computer to slow down
    Oct 15, 2009 | HP Compaq 6735s Notebook
    COMPUTER STARTS AND RUNS SLOW.. CHANGES PROGRAM VERY SLOW.
    some tips:
    1. Kill unnecessary programs, you can do it from task manager.
    2. some program starts at startup of PC, they make PC slow, go to start>run, type msconfig and say ok, go to startup tab and the disable the programs which you do not want to start up during PC start up.
    3. downloan CCCleaner and run it.
    4. Keep C drive clean as possible, move as much items to other drive, less space on c drive can slow down you PC.
    5. Many files placed on desktop can make it slow.
    6. If you have low memory on your PC then you have to increase it.
    7. Virus or Spyware can make pc slow do thorough scanning of your PC.
    8. I suggest you to uninstall any programs which are not necessary.
    all the best.
    2667305
    Mar 13, 2009 | Dell Microsoft Windows XP Home Edition
    Microsoft Windows 7 Ultimate for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
