Satzo server error based on location - Computers & Internet
What is the password to open Satzo password hacking software winzip?
its user defined who ever gave you the program or put it on the p2p site you downloaded from the program set the password also if i new it i couldn't tell you as it is a hacking program which is illegal.
Jan 23, 2014 | Sony Computers & Internet
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Jul 25, 2012 | Computers & Internet
Server based pass word is now defunked, how do I gain access to my server based files?
If the server is closed there is no way the information can be accessed until the server is operational again, in a sense you are locked out. Do you know how long the server is down?
Jun 14, 2012 | Lenovo ThinkPad T61 7664 - Core 2 Duo...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:6/11/2011 7:02:40 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft...
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:8/1/2013 6:34:25 PM ----------
-- UFSx S/N : 56512
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DA0064A542600069
Jun 11, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
How to download hwk update client v 2.1.0
Upgrade log:
---------- HWK upgrade started:6/2/2011 6:35:55 AM ----------
-- UFSx S/N : 78650
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DE6985914260006D
Oct 07, 2010 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Cant seem 2 b getn the drivers 4 xp got a ml110 any gud sytz!!!
HP build the proliant range of servers to support server OS's like Windows Server 2003/2008 and Linux etc. HP do not support any drivers for these servers for Client OS like Windows XP. You are best to locate the base chipsets and locate the generic drivers on the OEM sites for the chipsets. HP is unlikely to post drivers on their site except for emerging server OS's and Current server OS's.
As you do not list which version of the ML110 nor which Generation, I can't point you in the correct dirrection.
Thanks
Feb 02, 2010 | HP ProLiant ML110 Server
When booting the system the following error message appears: SQLDUMPER failed initialization
the uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
May 13, 2009 | Microsoft Windows XP Professional for PC
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
