Related Tags:
This problem should be removed because:
Problem with Janome 6019QC Mechanical Sewing Machine
Singer/merritt 2430 bobbin fill
How do I fill the bobbin on a singer/merritt 2430?, Can't find the manual.
Solutions (1)
Best Solution
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Adjust timing on Singer Merritt 4530
Help! I'm trying to finish my daughter's Halloween costume and my bobbin thread isn't picking up. I've deduced that it is a...
Singer Merritt 8834-My bobbin Wheel is Locked...
Singer Merritt 8834 My bobbin Wheel is Locked :'( Motor working against this ... HOW do I Free the Locked up Inner sheel??? THX...
why does my singer merritt 4525 jam in the bobbin
why does my singer merritt 4525 jam in the bobbin area?
i need a manual for Singer Merritt 2430 sewing
i need a manual for Singer Merritt 2430 sewing machine rjholdren@nckcn.com
Add Your Solution
I need to know "where" to oil the 6019QC...
I need to know "where" to oil the 6019QC Janome sewing machine because the manual does not provide that...
hi my janome 6019 qc
hi my janome 6019 qc feet dogs won't rise
I have a Janome 300e
I have a Janome 300e with customiser 10000, Can I use Scan n Sew 2 with it ?
Hello I have just run off
Hello I have just run off two perfect rows using my QC 6019, went to do the third row and the bobbin keeps...
when i drop the feed
when i drop the feed dog foot to quilt, I have a problem with the bottom tension, every couple of minutes it makes a...
Fix-O-Meter
592
592 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Janome Sewing Machine Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
