Question about Ematic Wireless Headphones and Transmitter
Cant connect tv - Ematic Wireless Headphones and Transmitter
I cant locate the audio in connection on my tv
See here
http://images.owneriq.net/download/images/0/04babd9a-a6c7-4fae-bb73-9d8576241dce-000001.png
Now if you want to connect your TV to the stereo set to get the big sound while watching a movie, you need audio OUT from the TV TO the stereo. Sadly this TV does not have such a connection shown.
If you are feeding the TV from a set top box, use an audio out from the back of the box. If you don't have a STB, they are cheap to buy to get this connection.
Nov 07, 2013 | Element Electronics Televison & Video
I cant connect to the internet I have the cable going directly into the TV and I still cant connect to the TV can someone tell my why?
It is sad to say that Panasonic - 50" Model: TC-P50U50
lacks the ability to connect to internet.
It should have an Ethernet port.
Sep 29, 2012 | Panasonic Viera TCP50U50 50-inch Plasma TV
I have a panasonic TX P50 C3B 50" Plasma TV and want to connect it to a SC PT470 home cinema system only I cant see that I have a fiber optic connection on the tv and no matter what i try i cant get...
If you want to listen your TV on your Stereo system thru your Home Cinema receiver, you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV to "AUX input " or "Any input" of your receiver ( except Phone ) or "Optic Cable input" than just switch to respective mode corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
Take care and pls remember to rate me..If you cant succeed you can contact me for more solution..
Thanks
Jun 19, 2011 | Audio Players & Recorders
I cant connect my dvd player to my tv. Theres
If you connect the satelite to the tv, using the tv socket on the sat. and connect the dvd to the vcr socket on the sat. it should play through the sat. even with the sat. turned to standby.
Apr 12, 2010 | Televison & Video
Cant connect tv to laptop via htmi cable
You need to use the RGB input port on the TV
May 01, 2017 | LG 47LG50 47 in. LCD HDTV
I have an insignia 24 tv and i cant get the audio
You will also need to connect audio from the audio output on your computer to the TV. I would recommend consulting the owner's manual for your TV as is should include detailed instructions for connecting your computer. Search for your TV model number at InsigniaProducts.com.
Jan 05, 2010 | Insignia NS-24 TV TV
Cable to tv cant find tvs cable port
fisrtly check for a rf connection on your tv. if you cant find it buy a converter rf to a/v, this will help you to input your cable and have a/v out put which you can connect to your tv.
Jan 04, 2010 | Akai LCT3201TD 32 in. LCD Television
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Ematic Wireless Headphones and Transmitter Logo
50 people viewed this question
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
