Question about Swatch Watches
Remove swatch crown - Swatch Watches
How to remove bezel and crystal on Swatch Irony Watch?
The crystal can be blown off by compressing air inside the watch. First the crown has to be removed carefully without breaking it from its shaft. This can be done by binding yarn behind the crown and pulling it while swinging the yarn around, almost like pulling a tooth. Once the crown is removed together with its shaft. Find a thin tube to fit into the crown's hole and which can fit to an air pump's adapter. A thin bicycle pump will do. Have a screen ready to catch the crystal. Once compression can be established inside the watch, gradually add more pressure until the crystal pops off. It may be necessary to hit the pump to pulse compressed air, but do it gradually and be prepared that the crystal will pop off with a bang. This is a risky process and the dial with arms may blow off if something goes wrong.
Jun 14, 2014 | Swatch Once again
Tip
SWATCH - how to change battery in SWATCH watches
Follow this link and see how to change battery in your SWATCH watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/battery.pdf
on Aug 04, 2010 | Watches
How to remove the front glass of my swatch irony
remove the movement and press the glass out from the back. Not a job if you do not have the right tools. Suggest you send to a watch maker.
Feb 06, 2012 | Swatch Irony watch
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
Jun 01, 2011 | Swatch Watches
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me...
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Dec 11, 2010 | Swatch Irony Chrono #YOS414G Watch for Men
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
How to change a swatch beat watch to 12 hour from military/24 hour time
Go to the Swatch web site "www.swatch.com"
Select "watches"
Scroll down to "Customer Services", select "manuals"
Select and download the manual for your watch.
Jan 01, 2010 | Swatch Watches
Swatch Skin #SFK254 ,Time always late
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
Aug 04, 2008 | Swatch Skin SFK254 Watch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Watches Logo
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
