Question about Refrigerators
My kenmore fridge's ice maker is off and on leaving paper like deposits on ice cubes, could some sort of coating be coming off. The filter is change is directed.
  • 72 Answers
Sounds like you need the ice maker replaced, it is an easy job, a few screws and a wire harness.
Posted on Jun 18, 2009
Ice sticking in tray of ice maker
Sounds like the coating on the ice maker is coming off, look where the cubes set and see if it is discolored, if it is then time for a new ice maker. Good Luck!
Jul 27, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Stop making ice...and water does not come out of unit. Ice seems to be frozen in upper unit that dumps into storage container.
remove unit. wash it out, remove all ice. try coating the ice cube area with some PAM NON FLAVORED spray..LIGHTLY.. usually, the ice maker is attached by a couple of screws, then you can get to the power plug, to detach and remove it. Overtime, the ice cubes will stick to the surface sometimes the PAM spray will help the ice slip out, but if it continues, you may have to replace the tray ( especially if the tray is nylon and the surface is pitted from deposits from the water- replacing the filter at least annually if not every 6 months makes them last longer) if there is no filter to the water supply, get one.
Dec 26, 2010 | Refrigerators
Have an Elite 795.76282600 model and the ice tastes awful. Does it have a filter we need to change?
If your unit has a filter yes for sure you would need to change the filter.If your fridge has filter cheak your manual for part number or on the net.
Nov 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
