Question about Tablets & eReaders
Tablet Smartphone how can i replace screen protector without air bubbles like Pro does ?
  • 22 Answers
1) Make sure device screen is ABSOLUTELY clean.
2) Make sure your hands, and workspace are also clean and lint free, then DOUBLE CHECK #1 above.
3) The pro's use a "wetting" solution to settle the protector onto the screen but NOTE ! wetness is generally bad for electronics !, so " a little, is good. More is NOT better!"
4) A small plastic squeegee is usually included with any "quality" protector kit. USE IT GENTLY! move the squeegee from the center toward the edges, pushing excess solution or bubbles as you go. Excess pressure stretches the protector and causes bubbles to form as the protector settles.
5) Once the protector is bubble free, in the correct place, and not hanging over the edges. LEAVE IT ALONE 'TILL IT DRIES AND SETS.
NOTES If your protector is one that uses an adhesive coating to hold it in place, DON'T TOUCH THE ADHESIVE SIDE WITH FINGERS (or anything else for that matter) because that's what makes dimples that trap bubbles. This process is proof of the saying "You only get one chance to do it right the first time!". If after the process is complete, and if you find there are still bubbles, you may try again but the likely chance of removing and replacing the same film without damaging it is very small. Fortunately, protector screens usually aren't too expensive (compared to the price of a damaged phone/tablet). Good luck!
Posted on Apr 16, 2014
Last time my son was playing with his pendo pad his tablet shuts down itself and cannot be charged.. not working obviously
I would try another usb cord and wall adapter. If this does not work, you can find out if the tablet is still under warranty. If it is not covered then you will have to find out if it is better to repair or replace the tablet. You probably want to install a case and screen protector on the tablet he ends up using.
Aug 07, 2016 | Tablets & eReaders
Install 10 screen protector for tablet.
Most screen protectors are peel and stick. Measure to the screen before applying to get right size, cut down.with scissors, if needed. Then just peel the backing off and very carefully align the edge and smooth into place.
Jun 01, 2016 | Tablets & eReaders
Need a user manual for a andriod dx758 pro tablet quad core 7in screen 8gb
Amazon.com : iROLA DX758 Tablet PC- 7", Quad Core ...
www.amazon.com/DX758...Android.../B00U1Q1156
Amazon.com, Inc.... OTG cable, screen protector, stylus pen, carrying pouch, user manual. Industry ... Kocaso DX758 8GB 7" Kids' Tablet with Android OS, Protective Case, Stylus, ...
Dec 20, 2015 | Tablets & eReaders
Its a crack inside my screen and i didnt know how to fix it so i opened my tablet to see what was wrong and i didnt see anythning. so i put it back together and its not turning on!!!!!!! please hel
(1) Is the battery charged? I'd connect the charger for at least 10 to 15 seconds anyway, while doing the following step.
(2)Are you holding the Power button long enough when you try to restart the tablet? It will need to be held down for a few seconds (perhaps 5 or 6) while you wait for the TRIO start-up screen to appear. Once it gets there leave the tablet to boot up fully.
If that does happen without further glitches should be able to go back to using the tablet as before.
(Was it working even with a cracked screen? Were you able to get the cracked touch-screen - I'm assuming that was what is cracked- to accept your fingertouch-inputs? Can you select items from all areas of the screen? If it was doing THAT, and it does it again NOW, I'd forget about the cracked screen , put a screen-protector on my tablet and press on ahead! Lucky dog!)
Nov 30, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
I crack the screen on my ematic tablet an it won't unlock how do I fix it
I'm afraid, till you have another screen it wont work correct again. Goto a phone / tablet repair stop and ask them what it will cost you if they replace the screen. If you like the price they are asking, use their service. If it is to expansive, start saving for a new tablet. and perhaps a screen protector too?
Oct 31, 2014 | Tablets & eReaders
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
How do you get bubbles out of iPad screen protector?
To lift the protector off one edge of the display, place a sticky tape on the edge of the protector and then pull on the sticky tape to lift off the protector.
Lift the screen protector from one edge, peel it back to the last bubble then re-fix the protector in place by slowly apply pressure across the proctector as you push the protector onto the display making sure no bubbles forms between the display and the protector.
Dec 28, 2011 | Apple iPad Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
