Question about AutoCAD LT 2014 for PC
How can i convert an AutoCad DWG File To PDF Format
    New Friend:
1. Close AutoCAD.
2. Install a free PDF Reader that incudes a virtual PDF printer. (Like NitroPDF)
3. Make the Virtual PDF Printer your Windows Default Printer.
4. Start AutoCAD & Plot/Print to the Default Printer, just like you print to any other printer. During the printing process, you will be asked for a file name & location to save the 'Printed' PDF file.
Posted on Apr 19, 2014
My valuable .dwg file has trouble
If a file cannot be opened, take the following steps for repair dwg
In case it can't be effective, then you have hard issue, see and learn more professional articles, guides and etc.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-repair-AutoCAD-Installation.html
http://www.thesourcecad.com/recover-damaged-or-lost-autocad-files/
https://dwg.recoverytoolbox.com/
  • RECOVER command
    --Recovers a selected drawing file
    --If successful, open and run AUDIT command
    --Evaluates drawing integrity and possibly more error correction
    --Set system variable AUDITCTL=1 to create a report of audit results
  • RECOVERALL command (introduced in AutoCAD 2008)
    --Attached and nested xrefs are also opened, repaired, resaved, and closed
  • INSERT and EXPLODE
  • Start a new DWG with no template
    --Run INSERT and selected the corrupted drawing
    --Check the "Explode" option
Mar 20, 2018 | Autodesk Computers & Internet
Error AutoCAD 2016
DWG Repair Kit is a program will show you how to repair dwg files online.
Here the link: http://www.dwg.repair/
Best Regards,
Roger Mason
Oct 07, 2016 | Computers & Internet
How to view damaged dwg file of autocad?
Try using a different version of AutoCAD to open the drawing, such as AutoCAD 2013 vs. AutoCAD 2015 or plain AutoCAD vs. AutoCAD Architecture, etc. Try different computers if available. or try DWG Viewer Tool on website:http://www.ask.com/answers/722146801/how-to-view-corrupted-autocad-drawing?qsrc=14106
May 29, 2015 | Autodesk AutoCAD Electrical 2013
How to recover AutoCAD files from flesh card?
If you need to recover it as fast as it possible install Recovery Toolbox for DWG , this thing is able to help you. But it's not free. Download free demo here:
http://www.dwg.recoverytoolbox.com/
As one of solutions I can advise you to try to open your files in MS Visio, Compass or using another program which could open dwg file. Or try to recover them using AutoCAD recovery function.
Also you can read here about dwg file corruption:
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/561-how-to-recover-autocad-files-from-flesh-card
Nov 27, 2014 | AcroCAD Software AutoCAD DWG to PDF...
How to recover a autocad dwg. file from bakup file
You may recover .dwg file with dwg corrupt file repair
Material http://www.autocad.repairtoolboxx.com could be interesting for autocad files
Feb 07, 2013 | Computers & Internet
What software do I need to convert word, jpg and other files to PDF format?
The easiest way I've found is to use CutePDF. It installs itself as a virtual printer, only when you "print" to it, you get a PDF document output. Download it for free here http://www.cutepdf.com/products/cutepdf/writer.asp
Feb 04, 2011 | HP Computers & Internet
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
AutoCAD LT 2014 for PC Logo
80 people viewed this question
Top Autodesk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Autodesk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
