Question about Android Apps
How can i boost and speed up my Wifi network reception ?
How can i boost and speed up my Wifi network reception mapping the clear channels in my area and boosting my reception
    New Friend:
Firstly download WiFi Analyser from Google Play store and compare you WiFi with others in your area. This will enable you to change the channel. Change channel by logging into your router - 192.168.1.1.
Try moving your router to a more central place in your home and use the analyser to check if any improvement.
Next try a wireless extender. This will drop your speed a little but give a stronger signal in weak areas.
Also try power line adapters.
If you are using a few devices ensure that you are not mixing wireless g and n products at same time. Using a g product will mean that your whole wireless will be running at that speed even when your other device is n. If you need both connect another g router to one of the n router LAN ports with dhcp disabled. That way you can have the two devices connected at the correct speed.
Some routers will let you connect a bigger aerial which could boost you reception. Some devices have very poor wireless antennas - seems you what you pay for in this area.
Posted on Apr 16, 2014
Is there any way to get a better wi-fi single
Some of the very common causes of poor Wi-fi reception include- the Wi-Fi router is placed too far from the device on which the Wi-Fi network is being accessed, too many devices are connected to the Wi-Fi network simultaneously, or Wi-Fi settings are incorrect either on the router or on the device which accesses the Wi-Fi network. There are many more reasons that can hamper your Wi-Fi connectivity.
You can refer to the following links to understand the issue you might be facing and to find a suitable resolution for the same:
(Important: Following links are of third-party websites. Hence, we recommend you to update your security software thoroughly before accessing the links. Also, avoid accessing a webpage if its access is denied or a security warning is issued by your Windows or security software.)
(Important: Some of the resolutions mentioned in the following webpages may be technical in nature. We recommend you to try only those resolutions that you find convenient to execute. Take professional help wherever necessary.)
http://www.wikihow.com/Improve-WiFi-Reception
http://www.pcadvisor.co.uk/how-to/network-wifi/3428611/boost-wi-fi-signal-get-faster-wi-fi/
http://lifehacker.com/5931743/top-10-ways-to-boost-your-home-wi-fi
Hope this will resolve your issue.
GuruAid.com
Jul 24, 2014 | Computers & Internet
Boost wifi signal strengh
Buy a wireless access point or router that supports AP mode. Set one device on channel 1 set the other device on channel 6 or channel 11. Give each device the same SSID. So if your network is called Gopher, set each devices wireless network name to Gopher and security settings are the same. Channels 1,6 and 11 frequencies do not interfere with each other, this allows each devices signal to overlap but effectively operate as the same wireless network.
Nov 27, 2012 | Monoprice Wireless 802.11N Router w/ WPS &...
I have spotty reception for the wifi in areas of the house where last week i had strong reception. nothing has changed physically
Try to change the channel in your wireless adapter if you have more wireless networks that you can see in you computer.
Sep 21, 2011 | Dell Computers & Internet
How do you update your gps
Do you mean the maps or the satellites?
Maps: you need to ask your GPS vendor if he/she have a free update; if not you can always buy a new one.
Satellites: go out when there's a clear sky and you are in a area with only a few buildings (clear of obstructions), switch ON the GPS and wait for a couple of seconds. Depinding on your GPS you can also use the WIFI networks.
Mar 15, 2011 | GPS
I want to boost up my internet connection
1. Position it better 2. Change the WiFi Channel : Wifi routers transmit their signals on a radio frequency of 2.4 GHz 3. Update firmware or drivers 4. Buy your equipment from the same company 5. Replace your antenna 6. Replace your wireless adapter 7. Add an additional Wireless Access Point (WAP) or Repeater
i know this is going to sound funny but try weird things like: Apparently aluminum foil amplifies reception and transmission. It may or may not work,
Sep 15, 2010 | D-Link Router
I only have two bars on my wireless network and would like get a better connection. I would like to surf channels to see if i can get better reception
Try placing the router closer to the center of the house, and in a higher area, and away from cordless phones, and high voltage wiring.
Aug 31, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
One channel on LCD not clear picture help!
this is a problem with the reception in your area. It should be resolved with an adjustment of your antenna to a location of clear reception.Ask someone in the house watch the television while the antenna is being adjusted for best reception and set the antenna. If you have cable, you must contact the cable company and ask them if they have a resolution to the reception problem. Hope this helps you with your problem.
Apr 25, 2009 | Insignia LCDTV26 26 in. Television
Android Apps Logo
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
