Can't use catchup &damand message on screen network availability (n33)
Cannot record externally from Humax bt you View box onto Toshiba RDXV60KB ( HDD & DVD modes). As I previously could? I am getting message E26 " Cannot record from this program". But the Tos
This error e26 gets thrown up on some digital rights management programs.this really just means you are not allowed to record...ever increasingly thanks to the big corps like sony drm carrier signals are put into some broadcasts to overcome copying infringements.there still is a way to do this with the right equipment.some tv channels get revenue from their advert counts so they put these signals in to ensure that you can only watch at broadcast or catchup on certain devices.what I can't figure out is I can record anything whilst it's being aired and still transfer to older equipment but not anything with latest ios and certainly not with sony recorders.
Jan 26, 2015 | Toshiba RDXV60KB DVD HDD VHS Recorder
I cant get my new sony Bravia to play any catchup programmes. I can access the catchup/iplayer sites but they wont play selected programmes.
Hi
This may not be as helpful as either of us would wish, but I had the same problem with my Finlux TV. It seems to be a fact that they do not make all programmes available on "Catch Up", as I found out one day when trying to watch something on Catch Up online, when some of them were only available for a very short time unless you were subscribing to one of the major entertainment suppliers.
Cheers
Jan 01, 2015 | Sony Televison & Video
Sim not valid 100
What is your phone brand?It is Nokia 100 ?If the phone displays invalid sim message on the screen.It is locked to network.You need to unlock it.To unlock your Nokia 100 use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check code is available for your network and country.If it is available get it and unlock it easily.Then use any GSM network sim card.It will not display invalid sim message on the screen after unlock it.
Jun 11, 2013 | Cell Phones
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Lg network 3d blu ray home theather model# lhb336 problem/boot and please wait
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
Dec 12, 2012 | LG LHB336 3D Wi-Fi Ready Bray Home Theater...
Cant get internet settings
For most cell phone networks and operators, Internet and messaging settings come pre-installed on your phone. You can then start using the Internet and send messages right away.
To download Internet and messaging settings:
  1. From the Home screen, tap the Application screens icon.
  2. Find and tap Settings > Sony Ericsson >Internet settings > Accept.
To configure Internet settings manually:
  2. Find and tap Settings > Wireless & networks > Mobile networks > Access Point Names.
  3. Press the Menu key.
  4. Tap New APN.
  5. Tap Name and enter the name of the network profile you want to create, then tap OK.
  6. Tap APN and enter the access point name, then tap OK.
  7. Tap and enter all other information required by your network operator.
  8. Press the Menu key and tap Save.
Note: Contact your network operator for detailed information about your network settings.
Dec 02, 2011 | Sony Ericsson WalkmanĀ® W995 Cell Phone
I am trying to connect a wireless ready Samsung blueray player to my Motorola Surfboad and it says to press the wps button on the surfboad, where is it?
NOTE: [] & "button(s)" represent features on the remote controller. {} & "key(s)" represent features in on-screen menus.
ROUTER INFO: WPS is on the SBG901.
BLU-RAY DISK PLAYER: You did not mention the model # of the Samsung Blu-ray disc player, so this information is somewhat generalized.
PREREQUISITE: Once you have attached Samsung's proprietary wireless adapter to that Blu-ray player, have connected that Blu-ray player to your TV, & have powered on that router & Blu-ray player & TV, access that Blu-ray player's initial settings menu.
STEP ONE: From the Home menu, press ?? buttons to select "Settings." Press [ENTER].
STEP TWO: Press ?? buttons to select "Network." Press [ENTER].
STEP THREE: Press ?? buttons to select "Network Settings." Press [ENTER].
STEP FOUR: Press ?? buttons to select "Network Type." Press [ENTER].
STEP FIVE: Instead of using the the "PBC (WPS)" selection, press ?? buttons to choose the "Wireless" selection & press [ENTER].
STEP SIX: Press ?? buttons to select "Internet Protocol Setup." Press [ENTER].
STEP SEVEN: Press ?? buttons to select "Auto" or "Manual." Press [ENTER].
IF SETTING UP WIRELESS CONNECTIVITY VIA AUTO NETWORK SEARCH: If you selected "Auto," press the ? button to go to "Access Point Selection." Press [ENTER]. Upon searching for available wireless networks, it will display those choices in a list.
A.) In the list of networks, press ?? buttons to select your network. Press [ENTER].
B.) IF "PIN/Security" DOES NOT POP UP, THEN SKIP THIS STEP; otherwise, press ?? buttons to select PIN or Security (Security Key--the usual option), & enter your network's Pass Phrase on the Security screen. (This Pass Phrase would be what you would use to access the network. IT SHOULD NOT THE PASSWORD WITH WHICH YOU SET UP YOUR ROUTER!)
Press number buttons on the remote to enter Pass Phrase numbers OR use arrow buttons on the remote to move from key to key in the Security Key screen. Change the type of on-screen accessible characters by moving to the on-screen {a/A/1/?} key & pressing [ENTER] on the remote. (The character set changes with each press of [ENTER]. Once displayed on the screen, you can enter a letter by pressing the number button on the remote which corresponds to that letter key. Pressing that button repeatedly changes the letter. You can move to {Delete} & press [ENTER] in order to remove the last character entered. You can move to {Clear} & press [ENTER] to clear all entered characters (or just press the red [(A)] button. When done, press the yellow [(C)} button (or the {Done} key followed by [ENTER]).
C.) WAIT UNTIL THE CONNECTION CONFIRMATION MESSAGE DISPLAYS & THEN PRESS [ENTER]. You're back at the Network Selection menu.
D.) To test the connection, press ? to select "Network Test." Press [ENTER].
IF YOU REQUIRE ASSISTANCE WITH SETTING UP THE WIRELESS NETWORK CONNECTION MANUALLY, I SUGGEST THAT YOU READ THE MANUAL (http://www.samsung.com/us/support/).
Jan 08, 2011 | Arris SURFboard SBG900 Wireless Router...
Settings saved on other computer for the network do not match the requirements of the network now
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Dec 14, 2010 | NetGear WNR2000 Wireless Router
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
No network
This is your hard ware problem you need to take your RZR to a repaing shop, they will replace the network receiver chip.
Oct 01, 2007 | Motorola Mobility RAZR V3
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
