Question about Samsung 29 cu. ft. French Door with Cool Select Pantry 1/2 Refrigerator Bl
Samsung fridge not cooling
Fridge does not cool
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
The middle part of the freezer and the fridge from my samsung is too hot.
hi there, sounds like you need to clean the back of your fridge, dust maybe blocking your vents, causing poor cooling on your condensor
cheers
Nov 16, 2012 | Samsung RS2530BBP 25 Cu. Ft. Side by Side...
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Fridge freezer works but fridge element back of fridge does not defrost completely leaving lump of ice
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Electrolux Freezers
Freezer works ,fridge does not?
heatman101
Dec 12, 2010 | Freezers
I have a samsung cool n cool fridge freezer. The freezer has an electrical smell and certain items are are defrosting??? Temp. Has dropped a degree and is now at17 deg.
Sounds like the defrost heater under the freezer coils has burned
out.Remove back freezer panel and check heater with ohm meter
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Freezers
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Samsung 29 cu. ft. French Door with Cool Select Pantry 1/2 Refrigerator Bl Logo
98 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
