Question about Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop
E6 Error code
Thank you for the prompt reply. The problem does not appear to be associated with the child-lock. E6 continues to flash on the two affected cooking zones. The model is EKI 607.2 as I indicated previously. The oven instructions state to call customer service if an error code Ex is indicated.
My belling induction hob is flashing e6
Hi Don did you get this fixed as I have the same problem thank you
Oct 29, 2016 | Belling Cooktops
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Hob not working
It is child lock.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Kuppersbusch Glass ceramic induction hob with sensor touch controls and panon detection Metallic Cooktop Logo
129 people viewed this question
Top Kuppersbusch Cooktops Experts
Colin Stickland
Colin Stickland
Gil Shultz
Bill Boyd
Are you a Kuppersbusch Cooktop Expert? Answer questions, earn points and help others
