Question about Cycling
Trouble with back brakes/cable?
Having trouble fixing my rear brakes on my diamond back s:10 mountain bike. when i pull the handle the handle does not go back to its position and the brake stay fixed to the wheel, can you provide information as to where im going wrong trying to fix this?
  • 20 Answers
The brake line for the back seems to be stuck, make sure it's tight on the handle bar and the brake in the back is not overly worn or too tight. If the problem presists try replaceing the pads and brake line.
Posted on Jun 18, 2009
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
18" Frame
Bicycles in Brand:Mongoose, Gender:Men, Wheel Size:29" ' eBay
https://www.ebay.com > Sporting Goods > Cycling Equipment > BicyclesResults 1 - 48 of 80 - 29" Mongoose Status 2.6 Men's Mountain Bike, 18-Inch frame, White ... The Mongoose 29in torment mountain bike will provide for hours of ...
Mongoose 29in Torment Mountain Bike - Kmart
www.kmart.com/mongoose-29in-torment-mountain-bike/p-080W004611130001P
Rating: 5 - ‎1 review
Oct 27, 2012 - Enjoy Fresh Air with this Rugged Mongoose Torment Bike 21 Speed The Mongoose 29in torment mountain bike will provide for hours of safe riding in th... ... Wheel Size: 29 in. ... Gender: Male ... It's rare to find an aluminum frame at this price point. As I wheeeled it up to the counter, many people stopped to ...
Mongoose 29" Front and Rear Disc Brake 21 Speed Mens Torment ...
https://www.amazon.com/Mongoose-Front-Brake-Torment-Mountain/.../B075CQPV5... Rating: 4.2 - ‎3 reviews
... and Rear Disc Brake 21 Speed Mens Torment HD Mountain Bike : Sports & Outdoors. ... power; Alloy frame with formed tubes and internal cable routing for clean look .... Product Dimensions: 58 x 10.2 x 33.8 inches ; 52.3 pounds; Shipping ...
Mongoose 29in Torment Mountain Bike - Sears
www.sears.com/search=mongoose%2029in%20torment%20mountain%20bike Mongoose Torment 29" Mountain Bike · 2.0. (1)Sold by Sears. add to comparecompare now. Mongoose 29" 21Speed Mens Torment HD Mountain Bike.
Mongoose Torment 29" Mountain Bike - Sears
www.sears.com/mongoose-29in-torment-mountain-bike/p-00654966000P Rating: 2 - ‎1 review
Feb 23, 2014 - Mongoose Mongoose Torment 29" Mountain Bike 1 ... A durable aluminum frame handles rugged trails and roads; Front and rear brakes with easy-to-reach handles for safe stopping ... Wheel Size: 29 in. ... Gender: Male ...
Bicycles in Brand Mongoose Gender Men Wheel Size 29 eBay
May 29, 2018 | Mongoose Cycling
95 Corsica emergency brake not working, pulls all the way back not locking
ray365m hows the rear brake shoes if you have rear drums if there good try adjusting the cables at the bottom of the (e) brake handle pull the boot back theres a 10mm nut to adjust
Jun 28, 2014 | Cars & Trucks
I have a Kawasaki kx20s 10 speed boys mountain bike that needs the rear brake cable replaced and both the front and rear derailer gear cables adjusted or possibly replaced. Is there a manual or diagram of...
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Aug 26, 2011 | kawasaki KX20 Boy's BMX Bike
Handbrake failing to engage,any solutions ?
Look under vehicle and see if cable at equalizer is hanging low. If it is or there is a lot of slack in it, then you just need an adjustment.
Basically, release brake handle, loosen the already loose cable (via equalizer nuts). pull handle back about...8 to 10 clicks/ notches. Then tighten equalizer nuts. Check it by releasing handle and this should release the rear wheels.Pulling handle up should apply parking brakes
Jul 06, 2010 | 2006 Volkswagen Passat
Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
May 18, 2010 | Huffy Men Mountain Bike (26")
Brakes too tight
There are screws/bolts connecting the brake pad to the brake plate. Try moving them out. Also, it works off of cable tension. Extend the length of the cable by lightly unscrewing the cable at the brake mount until it pulls the brake plate open loosely, pull on the cable until your breaks are the desired width apart and screw it back in.
Advice: use locking clamps on the end of the cable so that when you unscrew it, it doesn't go back through the hole. Re-threading it is a pain-in-the-****.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Schwinn Mesa Gs Mountain Bike
My roommate borrowed my bike and brought it back broken. Then brakes do not work - I know nothing about repairing them. Part of the brakes - the cable that goes to the right side is hanging to the ground....
if the knob is still on the end of that brake cable, then you just need to tighten your rear brakes by squeezing on them and pull the cable taught... you should then be able to just slide the cable into a lil groove on the handle lever and slip the knob back into the hold on the bottom of the handle lever
Aug 14, 2009 | Shimano Cycling
X-cross mountain biker-brakes
this is something you need to take up with your local bike shop
Apr 12, 2009 | Mountain Sram Pg 950 11-32 Cassette...
Brake pads jammed on rear cycle wheel
Hi Moon river,
Make and model of the bike pls?
May 12, 2008 | Air Purifiers
Cycling Logo
125 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
