Question about Sailrite Ultrafeed LS-1 Deluxe Mechanical Sewing Machine
Spindle turns but not bobbin
I have a new ls-1 and trying to load bobbin, I put on spindle and push to end, disengage clutch. the spindle turns but not the bobbin so it won't load it. is there supposed to be a flange or spring or something to keep the bobbin moving with the spindle. thanks
2 Suggested Answers
mari7402
  • 9 Answers
SOURCE: needle not picking up bobbin thread. Seems
Try re-threading your machine
Posted on Feb 18, 2013
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
Bobbin Winder
I looked in the manual for this machine, and I can't find out what "E2" means to your machine. However, there IS a list of FAQ at the back of the manual that is generally helpful. The first thing I would do, though, is turn off the machine, push the bobbin winder spindle all the way to the right to engage it, then firmly push it to the left. When you engage the bobbin winder, it activates a clutch that diverts power to the winder; that clutch might not be totally disengaged. Also, make sure your buttonhole lever is all the way up, and you have not selected the twin needle function. You might want to contact Singer through their FB account and ask what E2 means.
Dec 10, 2013 | Singer 7442 Mechanical Sewing Machine
Elna supermatic bobbin winder will not spin
is clutch disengaged? inner wheel in flywheel, hold flywheel and turn inner knob towards you to loosen. put bobbin on spindle and move to right to wind. if youve done this already and no joy then bobbin winder tyre may have perished. try www.sewingpartsonline.com to buy new one
Oct 13, 2011 | Sewing Machines
How to wind the bobin on a singer 7050
To get that same thread onto the bobbin, you'll need to windit. Here are the steps:1. Removethebobbin from the sewing machine. If your machine has a free arm, you'llhave to remove this first. Open the bobbin door to reveal the bobbin case, forvertical loading models. If your machine has a drop-in bobbin (horizontalloading) you may have to simply slide the metal plate open, which sitsunderneath the presser foot.2. Lift the latchand pull the bobbin case out of the machine (for vertical loaders). Butfor drop-in bobbins, simply lift the bobbin out of the housing.3. Tip the bobbincase over and let the bobbin fall into your hand. (Some bobbin caseshave a latch on the side, that when lifted releases the bobbin). If the bobbinhas another color thread on it, use a new bobbin. Or, if it's not too muchthread, roll it all off and reuse the bobbin. Just make sure the bobbin youwind begins empty. (But in a pinch, you can wind a new color thread over theold color. Just know that you may have to rewind the bobbin fairly soon, as thedesired color thread finishes faster.4. Place yourselected thread onto the spindle and insert a holder over it, if there is one(usually on horizontal spindles only). Many machines just use gravity toretain the thread, so if your spindle is vertical and you have no such part,don't worry about it. If thisis a brand new spool of thread, you may need to free the end. Look for a smallnotch on one end of the spool. You may have to peel back the label a bit to getat it. Then yank it free.5. Loop the free endof the thread over the bobbin tensioner and any hooks on it. Thelocation of this part varies, but it generally looks about like this. Thread the end of the thread through the pinhole in the top of the bobbin. 6. Press the bobbinall the way onto the bobbin winding spindle. Make sure any springs orclips engage. Put it on so that the end of the thread that you put through thepin hole sticks out towards you (or sticks up, depending on if your bobbinwinder is at the top of your machine). 7. Disengage theneedle mechanism. Many machines have this control in the handwheel. It may require a push, pull or twist of the middle of the hand wheel.Check your sewing machine manual to be sure. The sewing machine may run fasterwhen winding a bobbin than when sewing and you don't want the needle moving upand down wildly. Engage the bobbinwinding mechanism. On some machines, it's done by pushing the bobbinspindle over to one side. You may also need to move the stitch selector to abobbin winding position.8. Hold the free endof the thread and, keeping fingers clear of all moving parts, press the footpedal or knee lever. The bobbin spindle will turn. If you have thebobbin threaded correctly, the bobbin will wind smoothly, evenly, and snugly,with perhaps a slight bulge in the middle. You should cut off the end of thethread you were holding in your hand (very close to the bobbin) as soon asthere's enough thread on the bobbin to hold itself in place so it won't slipout. This will prevent this thread from tangling onto any moving parts.9. Fill the bobbincompletely. It may seem like a lot of thread, but you don't wantto run out too soon while you're sewing. Many machines have a built-in deviceto stop winding when the bobbin is full, often a small blade that automaticallycuts the thread when the wound bobbin is full. If your machine has such adevice, let it tell you how much to fill the bobbin. If not, fill the bobbin nofurther than its edges. Hold the bobbinand case so that they are oriented as shown. Check that thebobbin will unwind in the correct direction. If not, flip it.10. Insert thebobbin into the bobbin case. Pullthe thread under the bobbin tensioner (a thin metal latch). The threadshould advance with a little resistance when you pull at it. Allow this excessthread to just hang. Lift the latch onthe bobbin case and hold it as shown.11. Insert thebobbin case into its housing. Make sure it is all the way engaged (youshould hear it click into place) and that the direction is correct. The bobbincase shouldn't spin and shouldn't come loose when you release the tab. Itshould be locked in. And the loose end of the thread should hang free. Do notclose the bobbin door.12. Re-engage theneedle at the hand wheel, disengage the bobbin winder, and set the machine backtoa straight, forward stitch. Thread the machine with the top thread as usual. Once the threadis through the needle, you must raise the bobbin thread. Hold the end of thethread with your free hand. Turn thehand wheel towards yourself. The needle should go down and back up to itshighest position. One full rotation should do it. The top thread will passaround the bobbin.13. Watch as the topthread pulls the bobbin thread up through the hole in the plate under thepresser foot. Pull the looseends to extend them, and continue to hold them firmly so they don't get tangledas you begin to sew.Closethe bobbin door before sewing.Hope this will help you. Good Luck.
Oct 08, 2011 | Sewing Machines
Hello, when trying to thread the bobbin, I turn the fly wheel toward me to disengage it from the needle mechanism but the bobbin wheel will not turn. It is an old machine a contessa 120. Could you advise...
Do you also need to press the bobbin spindle over against a stop to make it engage the bobbin winder? Many of these mechanical machines have a system where the bobbin winder is driven by a black rubber which is engaged against the main drive wheel in this way.
So, if you are disengaging the clutch, pushing the spindle over, and still no action, then it could be that this black rubber wheel has perished.
Try http://www.sewingpartsonline.com/elna-120-sewing-machine-parts.aspx this page, you will see the black tyre item I mean.
Might be something you'd prefer to ask a service technician to do as he could give the machine a good clean and lube at the same time, the older machines will keep going providing you can get spares and they get a good service from time to time.
Apr 08, 2011 | Elna 2007 Mechanical Sewing Machine
How do I load a bobbin?
There should be a small spindle up on top near the wheel (right hand side).
Start winding the thread on by hand a few wraps to hold it in place and put the bobbin on that small spindle, making sure it is going to wind the proper way. To find out what way it will wind you can first (without the bobbin) push the spindle to the right so that it spins when the wheel turns, turn the wheel by hand for this so you can see which way it is spinning the spindle. Is it clockwise or counterclockwise? Then put your bobbin on and push it to the right so that the wheel will turn the spindle as you press the foot pedal. You should have some sort of tension clip on the top left of your machine, it looks something like the top of a big screw or may be a flat hook. Put the threat under that so that it goes directly from the spool to the bobbin, NOT through the needle. As gradually as possible wind the thread onto the bobbin but not too full, most machines will stop filling it when the bobbin is full. If yours does not, stop filling it when there is still about 1/16 th of an inch room left.
Nov 21, 2009 | White Sewing 1866 Mechanical Sewing...
Winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Jul 26, 2009 | Elna 2007 Mechanical Sewing Machine
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Sep 01, 2008 | Sewing Machines
Sailrite Ultrafeed LS-1 Deluxe Mechanical Sewing Machine Logo
Top Sailrite Sewing Machines Experts
Derek Massey
Douglas Plant
Douglas Plant
Debbie
Are you a Sailrite Sewing Machine Expert? Answer questions, earn points and help others
